Decrease tramlining! Steeda G Brace works!
Discussion in 'Interior and Exterior Modifications' started by DrumReaper, Aug 17, 2016.
  1. Epiphany
    Epiphany Well-Known Member
    Vehicle(s):
    I like to disassemble things.
    Oct 11, 2015
    Global
    4,958
    6,157
    Occupation:
    Philanthropist and ballroom dancer extraordinaire
    0   0   0
    And mine went away when I installed R-spec wheels and Continental Extreme DW's, with a 305/325 combination mind you.
    Zitrosounds, stanglife and DrumReaper like this.
  2. 65sohc
    65sohc Well-Known Member
    Vehicle(s):
    2016 GT350
    Feb 7, 2015
    Fresno, CA
    741
    225
    0   0   0
    If you're diving into a corner and applying heavy braking, tramlining should be the least of your concerns.
    Tank and Zitrosounds like this.
  3. superman07
    superman07 Well-Known Member
    Vehicle(s):
    2016 gt350
    Jan 12, 2016
    columbus ohio
    1,423
    531
    0   0   0
    mine did too, but I bought the brace anyway.
    Do you get more road feedback and vibration over 90ish with yours? Considering getting all 4 re-balanced. Car is nowhere as smooth especially over 100. I get much more negative feedback from the wheel. Considering an alignment check also. Its completely smooth up to 80-85 though. The fronts are also not heating up any more than normal. Running them at 36-37psi warm.
  4. Epiphany
    Vehicle(s):
    Oct 11, 2015
    Global
    4,958
    6,157
    Occupation:
    0   0   0
    I'll have to travel to Mexico and get back to you.
    :ninja:
    DrumReaper likes this.
  5. Hughespj47
    Hughespj47 HughesPJ47
    First Name:
    Pat
    Vehicle(s):
    '16 GT350 Track Pack, '09 MINI Cooper S, 94 SHO
    Feb 15, 2015
    Colorado
    176
    I installed mine today and took a jaunt over my "favorite" rutted section of freeway. My conclusion is that the bar helps, at least a little. On lightly rutted sections, the tramlining was noticeably reduced and easier to control. On heavily rutted sections, the car still darts, but not quite as bad. I'm planning to track the car this coming weekend and will see if it improves handling.
    Installation wasn't bad. The hardest part, as mentioned above, is getting the knockouts out from when they punched the holes in subframe. I used a short stubby flat blade screwdriver to work the knockout back and forth until it broke free.
  6. Zitrosounds
    Zitrosounds Well-Known Member
    First Name:
    Harold
    Vehicle(s):
    Oct 20, 2015
    Madison, AL
    3,411
    2,155
    0   0   0
    DING DING DING!!!! THE WHEELS!!!! That is the cause of the tramming.
  7. OP
    DrumReaper
    DrumReaper Well-Known Member
    Vehicle(s):
    May 17, 2015
    South East
    3,620
    2,221
    0   0   0
    Smh...
  8. slc
    slc Active Member
    Vehicle(s):
    Apr 16, 2015
    NW
    42
    +1 on all points. The bar did make the tramlining less severe on my R.
  9. jonesd
    jonesd Well-Known Member
    Vehicle(s):
    2017 gt350
    Apr 25, 2016
    Houston, Texas
    198
    68
    Rating:
    100%
    3   0   0
    Has anyone else installed one of these? Thinking about ordering a set and trying it out.
  10. ITLRUN
    ITLRUN HiPo Joe
    First Name:
    Joe
    Vehicle(s):
    2017 GT350R HR186
    Dec 20, 2014
    Adairsville, GA
    827
    876
    0   0   0
    I can't wrap my mind around how this is supposed to help tramlining. I really and truly think the excessive tramlining I'm experiencing in my R is a function of the light weight CF wheels coupled with the sticky Cup2 tires. With substantially less rotational weight, the R wheel / tire combo has less of a tendency to want to stay straight.
    I will verify my alignment first. If this doesn't correct the issue to my satisfaction, I'd be open to trying the Steeda bar. [MENTION=25806]SteedaTech[/MENTION] [MENTION=7748][email protected][/MENTION] This is an inexpensive part. Send one to me and I'll give an unbiased review of the part. Message me for details.
    Zitrosounds likes this.
  11. ITLRUN
    ITLRUN HiPo Joe
    First Name:
    Joe
    Vehicle(s):
    2017 GT350R HR186
    Dec 20, 2014
    Adairsville, GA
    827
    876
    0   0   0
    I have an appointment at 9:30 in the morning with my local dealer to verify my alignment. After that I will drive it for a few days to see see if the tramlining is any better. I suspect that it will not be.
    Now, HUGE props to STEEDA. I was contacted by them and I will be installing their bar in the next few days to see if I can tell a difference before and after. As a matter of fact, I received their G Brace yesterday! The packaging was perfect and the shipping was extremely quick. It is very cool to experience this kind of product support on the forum. [MENTION=25806]SteedaTech[/MENTION] [MENTION=7748][email protected][/MENTION] Thank you for this opportunity!
  12. AMpowerJ
    AMpowerJ Well-Known Member
    Vehicle(s):
    2016 GT350 - Ordering ...
    Aug 20, 2015
    Blythewood, SC
    365
    235
    0   0   0
    FWIW after I installed the Vorshlag camber plates and had my alignment changed to around -1.8 camber my tramlining all but went away. And I have 305s on the front too.
  13. RoadRacer
    RoadRacer Well-Known Member
    Vehicle(s):
    2016 GT350
    Aug 31, 2015
    Skippack, PA
    166
    86
    0   0   0
    I installed the MM CC plates and have my camber set at -1.5 deg. This car tramlines terribly before and after the plates as well as before and after the Steeda G brace installation. I figure it's just part of the equation with big rubber on the front. btw, I love this car and the "active" experience of driving it. It did scare the shat out of me once when changing lanes on the Turnpike into a milled lane in a construction zone!:eyebulge:
  14. Hermz
    Hermz Well-Known Member
    First Name:
    Brian
    Vehicle(s):
    350R
    Aug 5, 2015
    San Diego, CA
    219
    160
    0   0   0
    Very curious to hear the results. For now, i'm just building my forearm muscles.
    [email protected] likes this.
  15. jonesd
    Vehicle(s):
    2017 gt350
    Apr 25, 2016
    Houston, Texas
    198
    68
    Rating:
    100%
    3   0   0
    Would love to hear how this works out for you. I installed my forgeline wheels and cup 2 tires and i went from no tramline to a noticeable amount on my bad country roads around here.
    If different tires will fix the problem i may just order some and sell my cup2 on ebay.
    I also ordered the steeda g brace, ill see how that does.
Loading...
Share This Page
