Decklid panel fitment
JohnnyMacklin
Johnny
None yet
@NJ3 Thank you for the info! Mine looked exactly like the picture in the first post and even though it's a little thing, it always bothered me. After making some adjustments to those screws it looks so much better.
merlin803
MI
clay
2023 Mach 1 P0004
Thanks for all the info in this thread, the deck lid not aligning with my lights on my 23 Mach 1 has aggravated me for about a year, lol.
I finally got around to giving this a try and it is much better now.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
Thanks for this info @NJ3 I had a slight misalignment with stock taillights and I thought I could fix that when I changed them for the ice white versions. After installing I still had the uneven bottom edge. I planned to use plastic washers to move the taillight out, but I noticed the taillight hardware has a sealing gasket to keep water out of the trunk. If the gasket and cup washer are not pressing against the hole in the sheet metal, water will get in. I ultimately abandoned the idea and accepted them the way they fit. Now armed with your info, I am going to adjust them to get that alignment perfect. My wash mit always gets caught on the decklid corner sticking out.
NJ3
Virginia
2015 Oxford White GT
I was going to use washers when I first attempted to adjust my taillights but when I noticed that sealing washer I knew adding washers wasn't going to work.
With time and patience you can get the taillights to line up with the decklid panel almost perfect.
I accepted the misalignment of the taillights to the decklid on my 2015 Mustang because there were so many panels that weren't aligned. But on my 2023 I couldn't accept it.
merlin803
MI
clay
2023 Mach 1 P0004
As long as the 3 adjustment nuts are tightened back up after adjusting the screws, is their any danger of the light not being properly sealed?
Kingballer
Cleveland
Jason
16 Magnetic Whipple GTPP (totaled), 22 Oxford GTPP
Just confirming the adjustment screws indeed move to adjust tail light/deck lid alignment. I used 5/32. Thx again!
luca1290
Italy
Luca
Wow! Thanks!
I'm going to adjust mine's!
RowdyRam
SE TX
22 GT
I think the same person that did all y'all's taillights at the factory did mine too. Gotta try this myself soon, it's been bugging me too. Almost every Mustang I see has this issue.
involutions
Northeastern U.S.
Tommy
2015 Mustang GT, 2022 Mach 1
I did this as well. Mine was out on the driver's side about the same amount as the OP's and it took exactly 1/2 turn to make it even with the passenger side. I The correct tool is a TORX E6 (which is the smallest I had and it worked fine) or possibly an E5.
jloshotz
NY
Jack
2016 GT Premium
My adjustment / set screw bolts were either 5mm or 5.5mm, worked perfectly to line everything up 👍🏻
Keith S
2023 GT
Wow, I had no idea this was such an easy fix!
I am not an OCD panel gap guy, but mine was really off and it bothered me from the day I picked up the car… Few minutes in the trunk, lines up great now!
GrabberBargeCaptain
Ah nice thread. Need to do this as well. Anyone know the torque spec on the tail lights nuts? In one of my past cars this was crucial to keeping the water out of the trunk, and if you overdid it, the tail light housings could crack.
AZ_Ryan
AZ_Ryan
Arizona
2015 GT Premium
Just snug it down lol. If you over tighten you will crack the housing. I can't see how water could leak in from way back there unless you are submerged lol.
RJSS550
2021 Ford Mustang Ecoboost
I have the same issue and just found this thread. I just ordered some form lighting clear taillights and was wondering if anyone can confirm if these aftermarket lights have the adjustment bolts as the OEM ones do or we have to do the rubber shims? I’m waiting for these taillights to arrive but also don’t want to try to turn the screws and crack them if they don’t have that ability.
