Comp Cams- has anyone installed them yet?
Supa LA
Supa LA
Drop a gear and disappear
So. Indiana
2015 Guard Metallic Mustang GT PP
Most intake manifolds only lose about 10-15 torque down low. The 30hp gain up top is well worth that brief loss in torque to me. I'm sure it would be the same with these cams.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
There's a difference from the 11-14 stage 3 cams and the 15-16 stage 3 cams:
From beefcakes site:
Comp Cams 2015 and Up Coyote CR Series Camshaft - Max effort street/strip - 2000-7500 RPM Range.
Features & Benefits:
• New lobes feature faster ramps, more lift & more area under the lift curve than previous Coyote cams
• Work w/ stock valve springs & new Ford mid-lock phaser system w/out requiring limiters or phaser mods
• 3 Grinds are available for N/A engines & 2 for boosted applications so there are options for nearly all vehicles
• All CR Series cams are no-springs-required for easy install; two upgrade spring kits are available
COMP Cams® 2015 Ford Mustang Coyote CR Series Camshafts are the first new cam and core series for 2015 and later Coyote engines. New lobes improve upon the 2011-2014 XFI™ Camshaft Series and feature faster ramps, more lift and more area under the lift curve. The cams work with stock 2015 valve springs and the new Ford mid-lock phaser system without requiring limiters or any other phaser modifications. Three grinds are available for naturally aspirated engines with two designed specifically for blower applications. All are no-springs-required for easily installation in the vehicle. However, two spring kits (part nos. 26113 and 26125) are available for those that would like more spring with high boost or who really want to push RPM limits. COMP Cams® 2015 Ford Mustang Coyote CR Series Camshafts are the absolute best way to unlock the power potential of the brand new Coyote engine. They are also available for 2011-2014 Ford Coyote applications.
*NOTE: These cams are for 2015 and newer Coyote engines ONLY.
Cam Specs
RPM Range: 2000-7500
Duration @.050": 235* I / 237* E
Valve Lift: .516" I / .514" E
Lobe Separation Angle: 131*
beefcake
Bethel
2018 Ford Mustang
you build the engine for the power level you want to be in, a stage 3 cam is for a high revving engine, that will rarley see low rpms
the lower the rpm , the lower the stage you want
z06psi
Evans, GA.
Andrew
The pot stirrer
Couldn't agree more. If you are chasing a peak number then throw an intake on and stage 3 cams on there. If you are looking to combine some low with high then do what I am going to do. Intake with a stage one to gain back some low with the intake I put on there for other reasons.
Vanquisher
US
15 Mustang GT
What would you suggest for a 350 manifold car shifting at 7600. If I could get some of the torque back down low but have it pull strong to 7600 would be a win.
beefcake
Bethel
2018 Ford Mustang
i'd go stage 3 at that rpm
Dragster
2015 GT PP
For those that have installed these, how was the install? Does Comp Cams provide instructions? I'm planning on doing a GT350 manifold this fall--along with oil pump gears, crankshaft sprocket, and balancer--and I'm wondering if I should just go all out and do cams while I'm in there. Just not sure how difficult it is, and I also need to check if Lund has tuned for them yet.
4V Mayhem
US
2015 Mustang GT Premium M6
Now that I've decided to keep my GT I am planning to do a set of cams, GT350 IM, LT headers...and later down the road a PD blower!!
Dominant1
Dr Frankenstang
good moves man...
Dominant1
Dr Frankenstang
Performance nut
TX
2018 Mustang GT A10
mine are getting installed as we speak...should be finished soon...
What stage? I'm curious about stage 2 myself... see if it limits low end loss (or even gains some) while giving a little up top.
Dominant1
Dr Frankenstang
stage 3 with upgraded valve springs, a gt-350 intake and tb, arh long tubes, and a circle d 5c converter. I wont lose any low end because the converter will allow me to rev it quickly to lock at 3600rpm right in the middle of the power band...
Performance nut
TX
2018 Mustang GT A10
Yep, good combo. I was considering NA but with no torque converter so that I could track the car.
Definitely post results/review. :)
