Can you use the cams from the previous generation Coyote?
I heard this as well on a cj pony parts exhaust video.Don't quote me on this but I think they changed the firing order for 2015. it went from the old flat head firing order back to the 351 or 302 order
we put the comp stage 3 in our 2011 car, it picked up maybe 1mph at the track, maybe ......I would go with heads/cams and power adder. Just haven't decided on power adder yet... I see comp cams has some.
Keep in mind for 2015 we basically have boss heads with Cobra Jet cams...
Does anyone know the stock cams Duration, Valve lift and Lobe separation angle?
All camshafts have a Lobe Separation Angle. It's inherent in the design. The stock came are just really really wide, like 126-139 wide and then are variable like 50 degrees.There is no lsa. That is set in the computer and variable since one is intake and other cam is exhaust.
