Clean throttle body?
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
Does anyone recommend taking the throttle body off and cleaning it? My CTSVs called for doing it, my 911’s did not. But when I looked at them they had indeed built up some carbon gook or something in and around the TB plate. I used spray solvent to clean them and the car ran a bit better after it. Anyone done this? Car has 46k miles on it now.
NGOT8R
Adrian
2019 Bullitt
I don’t know if this was correct, but I cleaned the throttle body on my 2019 Bullitt using Mass Airflow Sensor Cleamer. Sprayed it on a rag and thoroughly wiped the oil mist off the blade and walls.
DCShelby
DCShelby
DC
Robert
Do you have to do a TB adaptation if it’s unplugged to clean and then plugged in again? The 911 had to do it, with some sequence of using the start button.
NGOT8R
Adrian
2019 Bullitt
I didn’t have to and I even removed my tab from the intake manifold.
DCShelby
DCShelby
DC
Robert
Thanks. I’m surprised Ford does not have that on the maintenance list. For my V cars I had the sea foam cleaner injected and run through the intake system as the car ran. The TB plate and opening does it dirty. Even odd that Porsche does not call for it. On my 2009 it was dirty and needed a good cleaning.
Postal Bob
Long Island, NY
Bob
2019 Shelby GT350
Do the passenger side oil seperators, have any effect on how clean or dirty the throttle body gets?
Rapid Red
Woodstock GA
Greg
I bet that is true, it lost the positioning reference .
If you’re going to clean the TB, use a cleaner that is safe to use on throttle bodies. Do not use a product such as Brake Cleaner, Carb Cleaner, etc… some products are corrosive to the surface of the TB and some TB’s have a special coating on the inside walls and blades to ensure smooth operation.
I’ve always used this product on EFI TB’s without ever an issue:
https://www.crcindustries.com/products/throttle-body-air-intake-cleaner-12-wt-oz-05078.html
