Camshafts / Boost
Leonidas514
Oviedo, FL
Chad
2015 GT
Does anyone have any ideas on finding stock Gen 2 cams? I've done tons of research and they seem to work well with boost. I can only find Comp cams but I cannot find any reviews, etc... on them.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Wellllll comp stage 3 for your gen 2. I mean, your gonna replace the cams anyways.
Doesn't your 2015 already have 'stock cams' ?
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
It does but I'm keeping that motor intact. Im just building a complete new setup. You think those stage 3s are good? I've spoken to MPR and he recommended custom grind for a single turbo setup. FFRE said the stockers would work well. Brett Lasalla was running stockers making 1500 HP. Both comp and factory are the same cost, just kind of torn which way to go and cams are like top secret. Lol
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Yes the stockers work extremely well. 1000+ horsepower no problem.
in case you're wondering about the stock cam specs:
2015-2017 mustang GT cams:
Intake Cam Lift- 13mm, 260* duration.
Exhaust Cam Lift- 13mm, 263* duration
engineermike
La
2018 GTPP A10
I spent a few hours talking to (learning from) a cam lobe designer one day and he basically scared me away from anything aftermarket. Some aftermarket lobes are fine and some are junk, but without a kinematics expert on hand you and I wouldn’t know the difference. Ever since then I try my hardest to find a stock cam(s) that come close enough to the specs I want in an oem cam. If I were you I’d be looking at predator and CJ cams. If those won’t work then stock gen2 I guess.
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
Thanks man. I personally want larger cams, I feel it would breathe much better. I'll let you guys know what I decide. Thanks again
Leonidas514
Leonidas514
Oviedo, FL
Chad
2015 GT
I was also told by one of the builders that they have had fitment issues with aftermarket cams. Thanks
WildHorse
N/A or GO HOME
Puddintane
'17 S550
They'll be zero issues with comp cams.
Jackson1320
California
Jaxson
2015 mustang gt
If you are looking for stock cams they are $105-$120 each new from dealer so about $450 for a set
Black Dog
Looking For Trouble
In the Country
Fred
2018 GT Air Cooled Twins by Comp Turbo
Nuff said. Proof is in the pudding.
Jackson1320
California
Jaxson
2015 mustang gt
What do you mean by “ are the same cost” ? Because I know you are not talking about cost as in money.
gimmie11s
SoCal
Murica!
What are your goals? You feel it would breath much better? what does that even mean? At what RPM? How much power do you feel you will pick up? Where do you feel it you would begin to see gains?
lol at these threads.. just lol.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
If the OP is blower limited, he has no choice but to increase engine horsepower. Whether that's cams, exhaust, intake manifold etc. It will make more power boosted, with more naturally aspirated power.
