bolt stripped.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I wonder if this is more prone to happen when you're only installing a strut bar and not the firewall brace too. The angle of the dangle is different when you don't have the complete set.
RAVAGE88
CT
'21 GT Premium
Ah, Dude, that sucks. I noted while installing my new struts and camber plates how soft those studs feel while torquing the nuts down. The torque spec I used was 35 ft lbs, but due to the feel while getting close, I stopped short of that spec.
There is a way to replace the stud with the exact type that stripped and spot weld the new stud in place, but it's moderately involved. Knocking the stripped ones out isn't all that difficult. Just depends on how involved you want to get.
MB
Bullittproof
New York
2023 Mustang GT Premium Fastback - Race Red !
Buy some coupling nuts from McMaster so you can grab the threads that aren’t stripped.
agreed, it is stripped the ‘size’ of the nut, you have good threads above the stripped area that can be utilized…or an oversized nut ‘slipped over’ the stripped portion (or a stack of flat washers) and then a nyloc nut to do the work.
good luck!
GrabberBargeCaptain
CA
MB
Yeah. I didn't fully get to 35 ftlbs with my torque wrench either. Clearly the spec for these nuts/studs are so close to the limit of what they can withstand, and people's cheapo wrenches are probably off by 10% that you shouldn't trust them for stuff like this.
RAVAGE88
CT
'21 GT Premium
Yep, pretty crazy how the most accessible fasteners on the entire car and possibly the most fiddled with by the owners to change parts, add parts, etc., are the softest and lowest quality of any other fastener on the car.
I'll be adding a strut tower brace soon and will not be using a torque wrench on the nuts, but instead, a box end wrench that I'll use to feel where the stopping point is. It's also my opinion that those nuts are of such low quality that I consider them to be single-use. I didn't replace them the first time, but I'll be replacing them when I install the strut tower brace.
MB
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I think a little detail is the challenge presented if installing camber plates, because they might interfere with a replacement screw had that protrudes too far.
I had my struts out recently and took the opportunity to measure the head height of the stud from underneath the tower dome. It is only 0.10" high. Any standard pan head screw has a head height that is double that.
So for no camber plates, it should not be an issue. For camber plates, you might need to use a M10-1.5 flathead screw, and then drill out the stud from above, followed by countersinking the remaining OEM stud head from below. I'm sure that would be a hassle.
Otherwise I suppose you could grind down the height of a pan head screw. Then you could simply knock out the OEM stud from above.
Braco
Braco
Massachusetts
Miguel
Mustang Gt
NGOT8R
Adrian
2019 Bullitt
Go less on the torque (maybe 20 ft-lbs) and use blue loctite to make sure the nuts stay put.
CowboyJohn
East Texas
2024 F150 STX Offroad, 2015 Mustang GT 5.0
My son's 2015 has four studs (2 on each side) that are stripped/unusable. I saw where someone said that they are tack welded on the bottom side.
Can anyone confirm?
I'm thinking about knocking them out and replacing.
Any thoughts on the process?
Cut them off flush and then use a punch?
