Beefing up a 10R80
schmeky
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
Exploded Muffin,
Sorry for the late response. A and C clutches had heat scoring (burned spots about the size of a dime or a nickel).
Rest of the clutches looked very good to excellent.
deanm11
Northern NJ
Dean
2020 Mustang GT A10
schmeky, I'd be very curious if you have seen and have an opinion about the new Suncoast Pro lok valve body. I'm contemplating a 700-750rwhp Procharger build and was thinking that maybe it would live with stock clutches with all the line pressure and other improvements by just switching out to this valve body upgrade.
Bullit69
Manny
19 Mustang GT Premium Convertible
any additional thoughts gents? I’m on 60k for my 10R80.
I’ll be doing the sonnax clips, new filter and fluid and a new pressure regulator from Sun coast. I already have a tune from
juggernaut performance, which has been working quit well. Just trying to be proactive at this point. Tranny has been great. It takes it about a second delay to downshift though…
Where can I get a thermostat bypass?
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
I can send u the thermostat. Pm me if you want . I dont make money on it. Just charging cost of shipment and fabrication .
BoostKing
Brett
18 S550 5.0, 22 F150 Tremor, 22 Expedition Stealth
HP Tuners does not offer tuning tech support (and are also not very responsive). I suspect you purchased The Tuning School's course, In which case they do include 1 year of support with the purchase. I'm not sure which employee provides the actual support at this time, but they have at least one who really knows his stuff on the 10r80. You also may find more information, or another member willing to help in the Ford trans tuning section of the HPTuners support forum.
I know I'm late to the thread, but I'm researching upgrading my 10R80 and found this thread. Great info in here by the way.
I'm the guy at The Tuning School who wrote the 6R80/10R80 Ford guide. I do all of the Ford stuff, and now some of the Dodge as well.
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
Are you going to build it yourself or have someone build it?
Scat2018
New Jersey
Anthony
18 Dodge Charger scat pack
muffin,
I should have been more descriptive. Once my original 10R died, I bought a new Ford 10R VIN matched to my Mustang.
Tore it down and did the Sun Coast thing. My 5 - 6 flare, after the new trans was in, occurred at low speed, lite throttle only. Anything past about 3K and it shifted great in 1 thru 6.
When my original 10R was dying, it flared sporadically at 5 - 6, at any throttle position, but was consistent on the flare.
I never had a harsh 5 - 6 on the original. It just totally failed one day when it went into (or I should say tried to go into) 6th.
About how much is a 10r from ford ?
Scat2018
New Jersey
Anthony
I guess it’s a rebuild one
Scat2018
New Jersey
Anthony
That’s good to know !!
furdfan2018
AZ
Mustang
Great thread and info @schmeky. How is your car running with the trans you rebuilt?
Midwestracer
Fayetville Arkansas
chris
2018 mustang gt whipple
BUMP Any updates guys
schmeky
schmeky
David
FurdfN2108,
Really well with one exception. I still had an annoying 5 - 6 mini flare a low rpm (2,000 - 2,500). Not consistent, but still there.
Since I had made so many trans tune adjustments, I re-flashed the TCM with the OEM programming and started from scratch and built a new program using the HP Tuners guidelines.
This nearly fixed the 5 - 6 low speed flare, but still there. Then I started experimenting with Torque Management [TM] (was using shift timing and pressure before), and low and behold, I found the recipe.
As you reduce the TM numbers in the HP Tuners software, the ignition timing being applied is reduced. I was doing the opposite, which was wrong.
I nearly had it perfect, then I modified the "Oncoming Ramp Inertia" by reducing this numerically. This dialed in the 5 - 6 shift perfectly in the 2K - 2.5K range.
So to answer to your question, the 10R can be a real challenge to tune, but once dialed in, it's friggen' awesome. The trans hits hard in Sport or Sport+ and on boost, it's just fantastic. No issues to speak of all. I love it now.
It's working to near perfection all the way around. If it came this way from Ford, all the gripes would probably be non-existent.
