Battery care for winter
Airborne5.0
Ontario
Hi everyone, I would like to hear how everyone cares for their batteries over the winter. I previously left it and boosted it in the spring, I picked up a trickle charger from Amazon this year but am now getting sort of paranoid about a fire happening in my garage while away.
What does everyone do?
MNstang
Minnesota
2019 Mustang GT PP1
Last year I did nothing with my battery. I did start the car and let it idle for about thirty minutes every 4 weeks. I had it in my garage from mid December to late March. No battery issues this year. Your results may be different...
Dana Pants
Burlington MA
Dana
2018 GT PP1
you could give yourself a reminder to put a charger on for 30 minutes at the beginning of every 2nd month and get the same result as a trickle charger. Up to you.
Droog
Ontario, Canada
2020 Mustang Bullitt
Trickle charger. Cheap to buy, cheap to use, and your battery will last longer compared to letting it go dead and boosting it every spring.
WD Pro
United Kingdom
Lime GT
I understand your concern and I think I would make that decision based on the quality of charger you have bought i.e. known make = relax a little / unknown Chinese make = hhhmmm ....
If its a quality make I wouldn't worry about it too much, what's the difference to electrical stuff that's plugged in around the house 24/7 ?
If it still plays on your mind, just put it on a timer to come on twice a week for a couple of hours - at least that allows you to minimise the time / risk balance in your own mind :like:
Personally I have a CTEK and have put my faith in it being a quality item.
WD :like:
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
What trickle charger did you buy?
ORRadtech
Atlanta, Georgia
Did you get a trickle charger or a battery maintainer? There's a real difference between the two but people often use the terms interchangeably. A trickle charger delivers a low charge to the battery no matter its state of charge. A matainer has electronics on board to determine the batterys condition and deliver a charge appropriate to its needs. It also helps to prevent sulfating of the battery plates.
A maintainer will keep the battery charged and healthy and is as safe as any other electrical device that is left plugged in.
A trickle charger has the potential to over charge the battery which can lead to dangerous situations like the battery exploding.
So it's important to know what you have and use it accordingly.
A good option for caring for a battery over a cold winter is to remove it from the car, fully charge it then store it somewhere warm.
WD Pro
United Kingdom
Lime GT
A 'cool' place is better for long term storage of an out of service battery :like:
WD :like:
ORRadtech
Atlanta, Georgia
I know lots of people do this but...
Running the car at idle for a few minutes during the winter is not really the best thing for it.
Idling it never really gets it to full operating temperature to heat out any moisture and the warming/cooling cycles can induce more condensation than it would have just sitting. You'd be better off to pick a nice day occasionally and drive it for that half hour.
boB
boB
2019 GT PP1
ORRadtech
Atlanta, Georgia
kz
West Chester, OH
Mustangs & F150
I've done nothing. Last winter car was up on a QuickJack for month and half and not ran sometime before that. Battery was fine. In fact even now (it's 3+ years old) still shows as "Good Battery, 98% health). Trickle Charger crowd is overthinking it a bit (unless you have a car that has some parasitic loss).
WD Pro
United Kingdom
Lime GT
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
This.
I have a couple of battery maintainers that I move around to each vehicle in my shop monthly during the winter. Once I get a green light, on to the next one, repeat until the rotation is complete until next month. Along with normal use in the on season, I've found that doing so extends battery life significantly.
Airborne5.0
Ontario
WD :like:
This.
Hi everyone, thanks for the replies.
Thanks for the suggestion to put it on temporarily and then remove it as required vs leaving it in for the duration of the winter. A buddy who uses this year through the winter recommended it.
I purchased his recommendation.
NOCO GENIUS1, 1-Amp Fully-Automatic Smart Charger, 6V And 12V Battery Charger, Battery Maintainer, Trickle Charger, And Battery Desulfator With Temperature Compensation : Amazon.ca: Sports & Outdoors
Let me know your thoughts and advice please!
