B&O 10" sub replacement guide
Gregs24
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
By the way, wouldn't be easier to disconnect the wire connector from the bottom of the sub box, then reconnect it once the wires are attached to the sub? Poly-fil would make it that harder, but curious if anybody tried it that way.
It isn't difficult to connect the wires - just follow my post and make sure you do the bottom ones first to make it easier.
19GTDude
Kansas
Brian
2019 Ford Mustang GT
Could you guys post your polyfill purchases for this? How much do I need? I see everywhere from 10 oz bags to 2 lb bags. Thanks.
ManyfordsnoMustang
ChiTown
Steven
2019 Mustang GT convertible Magnetic 10 spd auto loaded; '04 Maruader SC, 1970 442 W30 Convertible, 2014 Fusion Energi
I used mineral wool insulation, didn't pack it completely but made sure all sides of the enclosure were covered with a couple of inches.
m3incorp
Georgia/Colorado
James
For those that keep asking how much polyfill to use; I'm sure you understand that polyfill is used to make the subwoofer think it is in a "bigger" enclosure, than it really is. First, you have to know what the volume of the stock enclosure is AND then you need to know the recommended volume for a specific subwoofer enclosure by the speaker manufacturer.
peoples1234
NC
2020 Mustang GT/CS
This isn’t particularly helpful. I’m not sure that anyone knows the volume of the stock enclosure and Ford/B&O don’t have any specific recommendations. It is an odd shape, so calculating exact volume would be easy (I’m sure it could be SWAGed).
I started with about 9.5oz of poly fill, and with the stock speaker it sounded like the sub was working too hard and distorted almost. So I took out about 2oz, and it sounded much better (too me). Since replacing the stock for the Pioneer, I didn’t change the poly fill amount...and it still sounds so much, much better than stock. Since upgrading and fixing the rear deck rattle, I am super happy with the the sound in the car.
m3incorp
Georgia/Colorado
James
I guess the point I was trying to make is, many keeping asking how much polyfill to add and the answer is, it will vary......as even you verified.
Pero
Slovenia, EU
Pero
2019 Mustang GT Fastback Ingot Silver MT82 MagneRide B&O
m3incorp
Georgia/Colorado
James
If anyone wants to buy the B&O stock subwoofer enclosure with the JL Audio 10w1v3 subwoofer installed, contact me, as I installed it and the very next week decided I wanted a huge subwoofer in the car. I also have the stock B&O subwoofer. Take a look at my Green Koenig build for pics.
WD Pro
United Kingdom
Lime GT
I think we ended up with a similar amount - I bought a 12oz bag and divided it by eye, I used between 1/2 and 2/3 of the bag :like:
WD :like:
Elp_jc
None
You don't want more than 8oz in there. I weighed it, and put exactly 8oz. It was pretty full, but not packed, so right on the money IMO.
Veteran
Italy
2020 GT white
I just got my new 2021 gt with B&O
i Have been thinking about the 10inch Pioneer as I agree the base is rather off.
instead of going for a 10inch, what about going for a really good 8” sub. The base will be a lot tighter than the 10 and fitting would be easy with a adaptor plate. Pretty much any 8” dual coil 4 ohm will fit.
Opinions ?
FreePenguin
Ohio
Donald
17 mustang
Opinions ?
use Forescan and disable factory eq, turn it iff
you’ll get more bass and cleaner music. The bass as stock, is rolled off aggressively.
