Any options for a lower HP supercharger setup?
Rapid GT350R
Rapid GT350R
Ogdensburg NY
Nick
2020 GT350R
Cheap is not the goal, I just don't want 800hp for the street. 650 would be a sweet spot, and therefore don't need a 3" exhaust, long tubes, E85, blah blah blah. Stays quiet and streetable.
pmor4243
Utah
Parker
2019 Mustang GT
The power you get from any of the FI options will be largely based on the amount of boost (pulley size) and timing (tune) you decide to run. Obviously there is more to it than that but that is a simple way to look at it.
I went with a Procharger P1X and with the initial conservative tune was around 550-600hp. Same Procharger with a smaller pulley and more timing, fueling, etc put down 700 at the wheels.
The difference between the power levels was the lower power level was only seeing about 5-6psi and the higher power level was around 10psi, so just different pulleys.
Pretty much any of the options out there can do what you want, it’s just a matter of running the boost levels that correlate to the power you want to make and coupling that with a good tune.
NJMike
2020 Jeep Trackhawk-2" Kooks, pully, CAI, cat back
Stage 1 Whipple is what that sounds like
NGOT8R
Adrian
2019 Bullitt
Let it eat! I saw this GT350 on I-75 yesterday. Drag pack, parachute and the unmistakable smell of E85 filled the air. He at least has to be running 9.50s or quicker to need a chute.
Rapid GT350R
Rapid GT350R
Ogdensburg NY
Nick
2020 GT350R
I just want a pre-made setup, maybe the Whipple would do it. I have done my time building custom turbo and supercharger kits on many cars in the past when it was all I could afford (diy). Now, I'd rather save time and frustration and just let someone figure the shit out and let me just bolt on, plug in and drive 😎
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Call Beefcake, He will give u EXACTLY what you want👍🏼
wazslow
PA
2016 Mustang GT/CS
A parachute is required for cars trapping over 150mph in the 1/4. But there are tons of cars with no parachutes that trap higher. There are also a lot of cars with parachutes that have never seen 150+mph.
NGOT8R
Adrian
2019 Bullitt
Yeah, I just assumed he was running 9.50s at over 150 mph with the way he was set up. He was still running a manual tranny because I could hear him shifting gears. I’ll keep an eye out for him when I visit the track and try and find out more info. about his setup.
f00man
West Coast
Aaron
2022 Mustang M1 HP
Love seeing GT350s in the wild, instead of being garage queens.
daSNAK3
Cary, IL
Jake
2021 GT
Get an ESS G2 Kit w/ 125mm pulley.. Easy install, great company.
wazslow
PA
2016 Mustang GT/CS
That won't help his low end torque issue like a positive displacement blower would.
