Adding ceratec to oil quick question
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I own a 15. One bottle per oil change here. It does quieten down engine sounds.
In my experience with both, Liqui moly MoS2 > Ceratec
Andy13186
I tried mos2 and it didnt do anything I could notice. Ceratec fixed my tapping and I had one of the worst ticks ive heard. What did you notice from mos2?
BmacIL
Enginerd
Naperville, IL
I don't have the tick, but MoS2 quieted my engine considerably. Very noticeable under load on the highway. Ceratec on the next oil change was louder in mine.
StangSteve
Hawaii
2019 Velocity Blue GT Premium
Has anyone tried the nano additive? Curious to hear about its results.
ForYourOwnGood
Central MA
2017 Grabber Blue 5.0
I put Ceratec in my car and it immediately sounded like a box of marbles. The horrible, horrible sounds in the top end continued until I got the oil changed. It now sounds normal again. I noticed zero benefits except the ability to sound like a hoopty about to chuck a rod any second.
Andy13186
you must be joking... What oil did you have in there? Were you massively over filled?
ForYourOwnGood
Central MA
Just the regular 5W-20 motorcraft stuff. Everything went back to normal after two back to back oil changes but the noise was obnoxious. All in the heads it sounded like.
18 Smoke
Columbus, OH
18 Mustang GT PP1 400a
You’re the one car on the planet, I guess. Did you shake it up before adding it?
ForYourOwnGood
Central MA
Not the only one that has had noise result from adding the ceramic slushie, no. I didn't say it damaged anything it just made noise and was annoying.
18 Smoke
Columbus, OH
Glad it didn’t damage anything. Just first time I’ve ever heard of it making noise
Andy13186
Why did you use it in the first place, was your car making noise before using it? I dont believe ceratec could even cause the noise you are describing.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
Not doubting you. But when I researched Ceratec I came across Zero posts saying anything like this happened.
ktp1598
Mount Washington, Ky
Bobby
2019 Kona Blue California Special
Quick question on it's use.. I have about 1400 miles before my next oil change. Should I wait till I change my oil to add it or is 1400 miles enough to coat everything?
Andy13186
I'd do one bottle now and also one bottle on next change.
