Adding ceratec to oil quick question
emix
Bucharest
Mustang GT manual LB
Hi everyone! I'm planning to add Ceratec to the oil on the next change, I have a 2017 5.0 car. As far as I understand one bottle of Ceratec is good for 5 litres of oil, so considering the V8 7.6 litres of oil requirement I should be using one and a half bottles of Ceratec. Do I put it on top of the 7.6 litres of oil or do I put less oil (450 ml less) and top it up with Ceratec for the full volume required? Thank you.
18 Smoke
Columbus, OH
18 Mustang GT PP1 400a
I have a Gen3, so I normally use 10.5 quarts(9.95 litres) and add a bottle on top of it. Seems to work well
NastyPumpkin
Michigan
2018 Boosted Mustang GT
Adding only one bottle is usually all it needs. Top it off with it.
Andy13186
1 bottle works fine. and "overfilling" by that much will not be bad.
NC85
CA
Missing
10 quarts and 2 bottles here.
Hivel
NorCal
Mustang GT
In my 2018 I dumped a 5 quart jug in first. Then I dumped two bottles of Ceratec in. Then I filled each of the now empty Ceratec bottles with the second 5 quart jug and poured the rest of the 5 quart jug into the engine. So, I only had 10 quarts in the crank case. So far; so, good.
Cheers,
18 Smoke
Columbus, OH
Hell, it takes 10.5 quarts for mine to show full on the dipstick. Then I add a bottle of ceratec. ???
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
I own a 15. One bottle per oil change here. It does quieten down engine sounds.
18 Smoke
Columbus, OH
Great I dont have tick yet !! You have tick in your car?
Only 3500 miles, but no tick and 900whp!
My brother’s 18 has over 10K also 1 bottle per oil change and no tick. Fingers crossed!!
gstboy69
P.R.
Tony
My brother’s 18 has over 10K also 1 bottle per oil change and no tick. Fingers crossed!![/QUOTE
Ouchhhhh 900hp!!!!:rockon::rockon::rockon::rockon:
What setup?
18 Smoke
Columbus, OH
Whipple Stage 2 20% lower, 3.87 upper, 15psi. Kooks LTH, Magnaflow X & comp cat back, Fore L2 triple, 1050X, E85
