93 octane?
saleen405
Northeast
Scott
2015 Ruby Red GT PP
Those who run 87, are your exhaust tips sooty?
They ain't sooty but salty from all this damn salt on the roads...:headbonk:
Semi
Utah
79 ford f250 7.5l/2015 gt pp ruby red
No kidding but today the damn snow finally melted and got to romp through all 6 gears finally. Tomorrow Freezing Rain...:headbonk:
Egoman
Oman
2016 Mustang Ecoboost
Okay in my country we have 91 and 95, what should i use? is the 95 an overkill?
tcman54
Stanghead
Palm Coast, FL
Terry
2016 Ecoboost
I think Europe (and I believe adjacent countries) rate their gas octanes different than the USA, so from what I understand Oman's 95 octane would be about the same as USA's 93 octane.
The maximum rated horsepower of 310hp in the 2016 Mustang Ecoboost was achieved with 93 octane gas, if that is what you want than go with the 95 octane that is offered in country.
Before putting any gas in your car though I would consult with local experts first.
TC :)
Egoman
Oman
The maximum rated horsepower of 310hp in the 2016 Mustang was achieved with 93 octane gas, if that is what you want than go with the 95 octane that is offered in country.
TC :)
Thanks i'll do a bit of research to confirm this :)
Egoman
Oman
TC :)
I did a bit of searching and you were right apparently the US use a different octane rating than the rest of the world called AKI (Anti-Knocking Index) which is basically the average of the RON (Research Octane Number) and MON (Motor Octane Number) thats why it looks like you guys have a lower octane rating when it is actually the same.
Since here in OMAN we use the RON to rate our fuel i should be fine running Octane 91 when i buy the Mustang GT which equal octane 87 in US and below are conversion rates for information.
US AKI--------EURO RON
87--------------91.1
88--------------92.2
89--------------93.2
90--------------94.3
91--------------95.3
92--------------96.4
93--------------97.4
94--------------98.5
95--------------99.5
96--------------100.6
97--------------101.6
98--------------102.7
99--------------103.7
100-------------104.8
pmr2000
NC
2016 Mustang GT Fastback, 1975 Corvette Coupe
Does anyone know the HP difference between 87 and 93 on a GT? From what I've seen appears to only be in the 1% range from a Ford comment?
I know its a big difference on the ecoboost like 40hp but if it is only 5hp on a GT any other benefits? I've since switched back to 87....
wireeater
Virginia
wheelwell.com
Rich
Shadow Black 2025 Mustang DH HP
Pretty sure there is a thread in the technical section about this.
jdoug
Regular Guy
SoFla
Doug
2019 Mustang GT A10
Gigantor
Arizona
Wes
2016 Ford Mustang GT Premium
You put 87 octane in a Yugo not in a high performance car in my humble opinion. Though the specs allow you to, does not mean you should. High Octane has additives to keep your fuel system clean
Hack
Minneapolis
Mustang, Challenger
I think that putting a higher octane fuel than is needed is a waste of money.
Low octane fuel also has additives to keep your fuel system clean.
millhouse
Simpsonville SC
2016 Ruby Red GT PP
High octane has the same additives that are in plain Jane 87 octane. Premium fuel won't keep your valves any cleaner than 87 octane.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
87 is fine. I switched back for winter and gas cost savings. Will run 93 when I put my tune back on.
jwhite
jwhite
Indiana
J. Brad
15 Gt PP Roush SC'ed/16 GT 350 TrackPack 1970 Mach1
As one poster said the higher the octane ratings the less combustible the fuel is. ECU will retard the spark on lower octane fuel the prevent preignition (engine knock). Biggest feet of older cars (engine knock) is valve train. The fuel will detonate before a valve is actually seated. This will do 1 of 2 things. 1 lose of compression from blow by the open valve and 2 the valve will get slammed into place by the detonation.
Higher octane fuels will also run much cooler.
I have 4 vehicles and 3 of them require at least a min of 91 octane gas from factory.
Gigantor
Arizona
Wes
Six automakers, BMW, General Motors, Honda, Toyota, Volkswagen and Audi, believe using Top Tier Gasoline that contains a higher-percentage of detergent additive from that required by the EPA standard, provides optimal engine performance. They claim that lower concentrations of detergent additive lowers the quality of gasoline and can leave deposits on engine parts, such as fuel injectors and intake valves, which can lower engine performance, vehicle responsiveness and increase emissions. BMW, General Motors, Honda and Toyota developed the Top Tier standards under which gas retailers must meet in order to qualify as a Top Tier gasoline retailer.
