2019+ Voodoo Changes
LFG_Cory
Orlando, FL
Cory
2018 SHELBY GT350 LEAD FOOT GREY
555 = GT350R
557 = GT350
MustangNY
NYC
2015 mustang gt and 2017 Shelby GT350
Im confused. I was under the impression it was confirmed that the pre 2019 GT350 and GT350R shared the exact same engine. what is this now regarding GT350R valvetrain components being different?
GrabberBlue
GrabberBlue
Phoenix
Alex
2017 Grabber Blue GT350
555 = GT350R
557 = GT350
This is only relevant for pre-2019. All 2019s are 555.
  • GT350R Timing Chains
  • GT350R Lash adjusters
  • GT350R Cam covers
  • GT350R VCT mechanisms
bauern
somewhere else
Robert
F150 Powerboost
Have we actually seen a motor with 4 sensors, or are we basing the 4 knock sensors on the bosses?
Both the Gen3 Coyote and the new Voodoo block use the same valley casting. As such, both blocks have 6 knock sensor bosses cast in. The gen3 Coyote uses the 4 outer bosses (sensors); the voodoo still only uses the 2 interior bosses.
olaosunt
Indiana
Looks like the Gen 3 Voodoo block may be a good foundation for a short block build for a 2018 GT since they share the same valley casting and the voodoo block has the right number of knock sensor bosses for 4 sensors .
It might be an alternative to buying and sleeving a new Gen 3 block .
I am assume the 18 heads with DI will also work with the Voodoo block .
dougie360
San Francisco, CA
Douglas
2019 GT350
I can't say for sure. However, it looks like it started from the get go of the 2019 Production Run. I say that based on all the engine data tags I've seen for 2019s bearing the same identifiers.
Just picked up my 2019 GT350 a couple of weeks ago. It's tag is K0019, and looking at the door jamb sticker, looks like it was manufactured Feb 7, 2019. So got to be one of the first ones off the line. Looked under the engine cover and yes, it says KA and 350R, so definitely the new engine build. :)
Idaho2018GTPremium
Idaho
2021 Camaro ZL1 A10
Too bad they couldn't eek another 14 hp out of the voodoo in its (possible) last year or production with all these improvements. 540 hp is a nice round number. :)
Shift
CA
a Ford
The motor is high-strung as it is, there'd have to be a lot of improvements to reach that number. Not worth it for the last year and half run of cars. Low production numbers, and you have to recertify the HP figures. Easier said than done.
Hi-PO Stang
Minnesota
2014 Shelby GT500
Everything I had read indicated the GT350 and GT350R shared the same engine prior to the 2019 model year. To now hear the GT350 R was different than the GT350 is a real revelation.
Darkane
Alberta
2016 GT350 Base
That’s an interesting thought. A DI 5.2...
Would it work?
bauern
somewhere else
Robert
F150 Powerboost
To sleeve a Gen3 Coyote bored to 3.700", you're looking at about $3600. depending on where you get the block. Less if you go stock bore. The Gen3 has a more open deck than the Voodoo, but a shouldered sleeve might equal, or improve it over, the Voodoo block.
olaosunt
Indiana
My engine builder can get me a Gen 3 Voodoo block for about $2500 so that’s some saving .
Any reason whey the DI heads would not work with the Voodoo block ?
I have a complete voodoo rotating assembly (new but Gen I pistons and rings ) and had been considering building a “spare “ short block starting with the Gen 3 Voodoo block for my GT350 but now considering using a CP and building a “5.2” spare for my 18 GT instead (if they Voodoo block will work with DI heads )
Either way I could reuse the OEM Voodoo pistons (already have the dimple for DI) which are said to be a high quality Mahle and upgrade the rods for some more savings ..
Cost for the FP build was going to about $5600(with Manley rods ) and for the CP another $300 since I would need a crank .
