Winter Storage
1stMustang-GT500
Reading, PA
Evan
2019 GT350R KR070, 2019 Ranger Lariat
My worry is cold, not moisture. I guess ill just see how it goes.
Either way, im super excited to get this R home Wednesday. I dont even know its dash #. Im guess 750+.
Tonymustang302
Chicagoland burbs, IL
Tony
2017 Turbo GT, 2019 GT350 racecar, 2021 GT500
so you’re getting a gt500 also?
Nfs1000f
Upstate NY
Neal
2017 GT350 & 2019 Ford Fusion SEL Hybrid
Ideally a heated garage is best. Cold is not going to harm your car, extended periods of moisture will.
Nfs1000f
Upstate NY
Neal
ANd in the winter it's super dry so...
In my particular case, moisture becomes an issue when the weather warms and the air comes into contact with the floor that is at freezing temperatures. This happens when the garage door is opened on a day above 40 degrees F. The 1st year I stored my car without tarps covering the floor, the underside of the car got so wet it was dripping off.
Moisture also comes from the concrete as well. Remember concrete is porous.
mrbillwot
Greater Boston Area
Bill
'19 Kona Blue w/blk roof & blk stripes GT350, 89 LX5.0 Sedan (Mustangs Past: 69's Coupe, Mach 1, & GT)
Seal it with a 2 part catalyst epoxy paint. Makes for a dry, harder, moppable, low dust, and less chance of mold or mildew floor than playing with tarps.
Not expensive - even Home Depot sells the DIY rusolium kits for little $. 15 years after treating my basement floor with it that surface is dry as a desert bone year round despite being 9' above seal level that is often rain saturated soil & sand. Of course if you have gutters dumping water right next to the structure you should fix that 1st but still do both.
Another project for spring.
Tonymustang302
Tony
what do you do? Im in chicago, you’re in wisconsin.....i have to suffer through a crappy detached garage til my new one is built in march which will be heated.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
I put mine in a family member's garage that has an extra space when they snow bird. It's insulated and attached but there's no real heat source going into the garage. I just don't mess with stuff too. I don't start it up or anything like that because it's not going to be driven anyway. Just check the oil, pump the tires up, fill the gas tank, cover it up, let her sleep.
Tonymustang302
Tony
just gotta get through this winter lol. Then 2 car deep garage insulated being built for my 2017 and the shelby
Tonymustang302
Tony
No had to pull the GT500 deal, change in circumstances and tired of waiting. I think the 350R will be the better value for me.
i’d of dome the same thing. First year of anything is never good (me being ex Ford mastertech)
