Whipple Stage 1 or 2?
pfarley1
Canton
Paul
2021 Mustang GT
Is the extra cost of the Whipple stage 2 worth it? Could someone explain the benefits of stage 2 vs 1?
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
Always stage 2, it’s wayyyy more expensive to upgrade to stage 2 later and it’s worth the initial cost for the power bump.
engineermike
La
2018 GTPP A10
Stage 2 is the pulley, throttle body, and tune I think. Most think it’s worth it.
pfarley1
Canton
Paul
2021 Mustang GT
Is the 5th gen 3.0 the one to go with?
Vert
Indiana
Whipped 19 GT Premium
You should also upgrade the heat exchanger to offset the heat from more boost and HP.
pfarley1
Canton
Paul
2021 Mustang GT
Is a BAP sufficient?
So injectors, tune, fuel pump (or BAP if confirmed), larger heat exchanger. Anything else or is that pretty much all that is needed?
TX-Ripper
SE Texas
I have no idea what your taking about, stage 2 comes with what you need.
pfarley1
Canton
Paul
2021 Mustang GT
Aren't their gears that need replaced? I guess I am referring to other things that would make sense to upgrade that aren't in the kit.
TX-Ripper
SE Texas
Sky is the limit, oil pump gears, crank sprocket, built motor, built transmission, return fuel system with e85, custom tuning.
you can go as far as you want.
the stage 2 comes with everything need to for you to make 650+ Wheel Hp with good fuel.
Vert
Indiana
If piece of mind, you can do the crank and oil pump gears when you install the SC to minimize the motor tear down process.
Supporting mode all depends on what your wanting out of the car.
Wider wheels and sticker tires are a must it you'll be doing any spirited driving.
engineermike
La
2018 GTPP A10
Pulley
Tune
Throttle body
Fuel pump
Injectors
The throttle body is the most expensive part. As tx-ripper said, it’s much cheaper to get the stage 2 from the start. I made that mistake in 2015, but didn’t make it again in 2018.
Please post any evidence you have of gen3 opg failures with bolt-on supercharger kits.
Inthehighdesert
NM
Charlie
I’d like some references on that as well if there out there.
Pulley
Tune
Throttle body
Fuel pump
Injectors
PayForYourGas
Menomonee Falls, WI
2018 Mustang GT A10
Doesn’t seem common but heres one. There’s been several on S550 Facebook groups, but I hate digging through them. Seems like mostly Whipple cars for whatever reason.
