Whipple Install and oil weight thoughts
bryontro
Bossier City, LA
2022 GT Whipple Stage 2
Getting ready to do a stage 2 Whipple install in my otherwise stock 2022 GT A10. I decided to do an oil change and move up to the 5W-50 that Whipple recommends. I wanted to watch oil pressure and get an idea of what the new "normal" would be with the heavier oil without having the variable of the SC already installed. Basically an 18-20 PSI increase in oil pressure with it hitting 100 psi with a heavy throttle (OEM digital dash). Then I realized a change in my "tick".
I have previously written off the intermittent tick that I have as "normal". It wasn't loud, it was intermittent and half the time when I wanted to show a fellow car guy the noise, it wouldn't happen for me.
Until this 5w-50 (syn Motocraft) was put in. Wow, now its audible from a distance away, intrusive (outside the car), and somewhat embarrassing... It has never been this loud in 16k miles. I'm literally going to pony up for another $100.00 and put 5w-30 back in the car and see if it goes away.
Question: If it goes back to what I'm used to (tick), I'm almost certain I will leave 5w-30 in the engine even after the SC install. Thoughts?
bankyf
Fredericksburg, Virginia
2022 GT500 CFTP
I really would have expected the opposite. Maybe try a bottle of Ceratec before you waste the new oil? I've heard enough cases of it solving the tick to believe that it works in many situations.
silverbullet85
San Diego
2019 Gt
I would second that you use 1 or 2 bottles of ceratec to see if that changes anything
TX-Ripper
SE Texas
2019 Mustang GT PP1 Whipple Stage 2 / 2018 F150 5.0 Whipple Stage 2
Sounds like it’s a mechanical problem
Pat-Red-PP2
Québec
2020 PP2 Loki Supercharger
VMP Loki and I go whit 5w30 full synthétique Motorcraft,after the installation of de Supercharger the New tune help ,the idle go up around 950rpm the oil pressure help for the tick I think..big déférence for me..because stock it tick a lot and now acceptable!
bryontro
bryontro
Bossier City, LA
I also expected the exact opposite. I picked up 5w-30 again yesterday. Will see if it goes back to what Ford calls "normal".
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
Thats funny. My car had a slight tick and when i went whipple and to Driven FR50(5w-50) it is gone. Engine is nice and quiet now.
bryontro
bryontro
Bossier City, LA
First and foremost I have to correct my observation. I had an increase of 8-10 PSI with the 5w-50 not 18-20 psi.
I replaced the 5w-50 motorcraft with 5w-30 Mobile 1 2 days ago. Once again it is not as pronounced as with the 5w-50 in my specific case. Its still there though. Just more intermittent and less often.
What I can say without question is that cold starts have "zero" tick until the oil comes up to temp. I've listened multiple times now and it is clearly not present during cold starts (temps around 40 degrees ambient).
This wasn't intended to be another tick thread. More on the reasoning behind Whipple's recommended oil weight when everything I have read and watched, and discussions with racing buddies have consensus that oil weight is related to bearing gap tolerances which "do not change" with the SC install. I'm staying at 5W-30 unless something profound comes up that supports the 5w-50.
Slopoke
Left Coast.
Ed
2019 Mustang GT PP1 10R80
I used the Motorcraft 5w50, when I first installed the Whipple and I just did a second oil change with the Motorcraft, because I overbought the first time and was able to get the balance from Oriley Auto, for ten and change a quart. The next oil change, I'm going to use The Pennzoil Platinum Euro 5w40. The price on Amazon is 9 per quart.
beetle6986
Harrisburg
16 Mustang GT, 04 Cobra, 2008 BMW 335
I use 5W30 also. Mine doesn't make any ticking noises, but it only has maybe 7k miles on it.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
One thing I have learned from riding Harley's is oil brand matters as far as engine noise goes.
RTR077
Denver, NC
James
2021 Mustang GT RTR Spec 1
For what its worth I use molygen 5w50 with my Roush charger. 5k miles, no issues.
Pat-Red-PP2
Québec
the engine tick New at the dealer🤷‍♂️ When I add the Supercharger it help ,the oil pressure go up at idle it help a lot,if you have no tic tac you are lucky!!!
sabtaj1
Bettendorf, IA
Jason
2019 PP1 Mustang GT, 1965 Fairlane 500 wagon
I use the Rotella 5w40 T6 stuff and one bottle of ceratec. Never had a tick until after first oil change. Now one bottle of ceratec with each oil change and its been gone since.
