Whipple front weight concern?
KT3
Toronto
Jay m
2019 Mustang GT
For my Whipple Mustang people... Did you notice any sort of drop at the front end after installing the whipple?
Currently on eibach pro kit (1 inch drop) wirh 285/35/20. I plan on getting coilovers eventually, but not right when the whipple is installed.
Just wanna make sure the rubbing doesn’t get any worse with the Whipple installed, otherwise I may have to get coils sooner than I anticipated.
J17GT
IL
2017 Mustang GT PP
With stock springs I'd say the front end dropped 1/4" or so after the whipple was put on.
Kobi Addiction
Houston, TX
2017 Ford Mustang GT350
Front did lower a bit more with the Whipple and accessories.
Avispa
Oldsmar, FL
Richard
2016 Mustang GT/CS convertible
Have a VMP 2.3 on this car, but the package weight is comparable. The answer to your question is "no."
KT3
KT3
Toronto
Jay m
2019 Mustang GT
Right on... Thank you. I have about just over half an inch of room in the front, lol.
Avispa
Oldsmar, FL
Richard
Don't know if the installation instructions say to remove a grounding spring tab from the underside of the hood, but you may want to check that out. My blower case has a groove worn into it near the back, and I just noticed it a few days ago? Lines up perfectly with one of those ground spring tabs. Don't guess it will eat all the way through the case, but still..... Give yours a look to be sure.
KT3
KT3
Toronto
Jay m
2019 Mustang GT
I called my shop and let them know I have a taller tire set up... they said i don’t need coil overs and i’ll be fine with the added weight....
Andrew@Lethal
West Palm Beach Florida
Andrew
You shouldn't have anything to worry about any crazy added weight in the front with a Whipple. BMR does make Forced induction rated springs if you're interested which would help keep the car planted. https://www.lethalperformance.com/b...t-drag-lowering-springs-forced-induction.html
