When to get oil pump gears.
jakefed4
Waxhaw NC
Jacob
2017 mustang gt premium
Hey everyone I have a FBO e85 manual gen 2 mustang. I’m putting on the ESS g2 supercharger in June. I will be at 650-700 whp. I plan on doing a billet crank sprocket while I’m installing it but I’m gonna have a shop do the oil pump gears. Do the oil pump gears need to be done asap when I’m boosted or can it wait a little bit. I don’t know much about oil pump gears i know it obviously pumps oil but is it one of the things where if it breaks mid pull then my engine is shot?
To answer your question:
If adding forced induction, do the OPG at the same time. You’re already investing time/money for the forced induction upgrade and will have things apart, so don’t skimp out…
OPG isn’t the only gear to be concerned with, specially if being boosted… look for threads on here regarding the crank snout gear too…
HKusp
Hampton, Md.
Jason
If it breaks, you're pretty much done. It's not the worst thing in the world. Basic set of hand tools and watch a couple of YouTube videos. Taking your time, start pulling things Friday night, and you'll be buttoning it up Saturday night. If you do the ESS install too, you'll be done Sunday evening.
Watch this guys installation videos: He does a nice job showing you how to do it.
https://www.youtube.com/@SpeedAddict731
HKusp
Hampton, Md.
Jason
He said he's doing the crank gears, so he definitely is going to be in the vicinity. I agree, he should just do it all at once.
Ls_Eater
Apollo Beach
Parker
2018 Magnetic Metallic GT
SheepDog
Colorado
Dax
Replacing the Oil pump gears is a lot easier on your car than on Gen3 motors, because you don't have to drop the oil pan (provided you get a little crafty with a wrench and piece of wire to start the oil pickup tube bolt during installation)
You can buy pre-assembled oil pump assemblies with billet gears in them to save yourself some time.
One thing to note, that is not in the Ford procedure-
Sometimes you will hear of people installing these, and then shortly after starting the engine, they get a vibration, or rubbing sound, or worse, metal shavings in the oil due to misaligned OP gears.
IMHO, when you slip the new oil pump assembly onto the crankshaft, you should also then install 2 or 3 of the bolts that hold it to the block, but only finger tight. Then, rotate the crankshaft a few times. This will allow the gear to perfectly center the oil pump housing onto the crankshaft. Once you return the crank to the correct position, you then torque down the oil pump assembly.
jakefed4
Waxhaw NC
Jacob
I definitely plan on doing them. I can put the ESS kit in but after watching videos on oil pump and crank sprocket I think it might be above my pay grade. Is this something that can wait a month or 2 after I’m boosted also if the OPG breaks does that mean the engine is done.
ORRadtech
Atlanta, Georgia
If a gear breaks it can't pump oil, bearings don't like being without oil. Not to mention the damage the broken gear itself will inflict.
I'd do it before, at the same time would be the latest.
jpjr501
Boca Raton, FL
Joe
2020 Mustang GT - Procharged
With a blower it's like insurance. You hope you don't need it but if you do you have it.
Get it done while getting your blower installed.
ToxicOverwatch
Oklahoma
2017 Silverado- extremely stock
Don’t rush the process. I know you’re excited, but have all of your supporting equipment squared away before you increase the powertrain load by ~50%. You will do all that work and every time you step on it, it’ll be in the back of your mind. Give yourself the ability to relax, and don’t risk a catastrophic failure.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
If Ford Racing/Whipple warranty the engines with the stock OPG's....
It's only for 3 years. Then you are on your own.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
if it hasn't broken in 3 years, chances are it won't. Just because some company adds the billet moniker, that doesn't mean shit. How many of you's check the tolerances on these aftermarket OPG's ? I'm betting not many.
daSNAK3
Cary, IL
Jake
2021 GT
not a gen 2.. but stock opg here.
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
Are you trying to justify saving a few bucks vs. blowing up your engine? What is the difference in cost? Gears are probably less expensive than a new engine but I am just guessing. Skinflinting here is not in your best interest. Curious as to how old you are. Really not putting down your choices, do what you want.
