What do I do now? MT-82 Woes
Wamp
Arizona
Collin
2015 Mustang GT
Morning Fam.
Last week I completed install of an MGW x-spec. Installed a McLeod RST last month. 2015 Mustang GT. Stockish power level. McLeod stainless clutch line, steeda spring, BG fluid and additive.
It still grinds and won’t go into gear shifting at 6000 and above. Yikes. Looks like a synchro issue.
Options I see:
Option 1: There’s a guy selling an MT82D4 near me. Decent price. Buy this and source a 2018 clutch. McLeod doesn’t even make an RST clutch for the 2018 except with an aluminum flywheel. Might be too rough for a daily driver
EDIT: Has anyone done this? Is there anything required besides the clutch and shifter? Another forum member suggested a sensor/connector needs to be swapped out to work
Option 2: Ben Calimer. I plan to go boost at some point. Stage 1 is $2391 shipped. Stage 2 is $3191 shipped. Stage 3 $4291. All 3 have a prepaid return for your core and a $500 refund once received. Stage 3 is pretty pricey and might be too much for a daily driver. (People online complain about awful noise and vibration with it… and it’ll be many months before I could afford it)
Option 3: Buy the parts online and have a local shop install. $575 labor if I bring them my trans. $900 if I bring them the car.
Option 4: ???
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Grinds in all gears above 6k?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Yes. Some worse than others.
So first through sixth + reverse. I'd guess its not the syncros. Release bearing is my guess.
Wamp
Wamp
Arizona
Collin
2015 Mustang GT
Well, to be honest, I’ve never tried shifting into reverse at 6k.
I did replace the throwout bearing with a McLeod one when I did the clutch, and that didn’t affect the grinding.
To be more specific, the “grind” occurs when I am at it above 6k rpms. Off gas, on clutch, attempt to put car in next gear with clutch depressed and gas released. The grind is not due to depressing the gas too early, or letting off the clutch before car is in gear. Grind occurs with clutch to the floor and no throttle applied.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Haha good one. Well seems younreplaced what you could.. Bled the rb properly.. Could be Shift forks.. Shift forks pads.. Take it out and get it rebuilt with FORD OEM parts.
Wamp
Wamp
Arizona
Collin
2015 Mustang GT
Yeah… bench bled and pumped pedal about 300x.
OEM is definitely an option. Wouldn’t be opposed to rebuilding with OEM plus bronze shift pads and a billet shift rail stop. We’ll see.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Rebuild yours, gearing is better versus the late trans.
1TUFF_S550
Richmond Ca
JESSE
2017 Mustang GT PP. 2001 Mustang GT Cam’d & Vortech’d
Ive been using motul dctf with ford modifier in my 17 mt82 after about 1k miles in. Got the car new now sits at 29k and have a barton shifter trans mounted(about 2500 miles on this setupq)and never had any issues grinding or not going into gear even shifting at 7600 rpms. Also have the steeda braided line.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Mines bone stock (including clutch) with the exception of RP SYNCHROMESH. No issues shifting at 7500 rpm. 50k miles.
Wamp
Wamp
Arizona
Collin
2015 Mustang GT
I had RP synchromesh before the BG… didn’t like it as much. Some difference in smoothness and cold shifting between the two. But neither seemed to fix the lockout issue.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
I won't. Its all how you treated the clutch in the first 500 miles.
Wamp
Wamp
Arizona
Collin
2015 Mustang GT
I don’t think it’s *all* in clutch break in… I had a grinding issue with my stock clutch, and had the same issue with the McLeod RST.
