V6 Ecoboost crate
Livernois Motorsports
Dearborn Heights, Michigan
www.livernoismotorsports.com
S550 HQ
2016 Mustang GT (TVS 2650) (6R80)
POWERSTORM FORD 3.5L ECOBOOST RACE SERIES SHORTBLOCK
PRICE: $7499.99
SKU: LPP750101
Components
3.5L Aluminum Block
Forged Crankshaft
Powerstorm Custom Coated Forged Pistons
Stainless Steel Ringset
Thick Wall Tool Steel Wristpin
Powerstorm 4340 Forged I-Beam Connecting Rod
Powerstorm billet upper block support
Tri-Metal Performance Main Bearings
Tri-Metal Performance Rod Bearings
Powerstorm Main Stud Kit
Machine & Assembly Work
Deck Plate Honed Cylinders
Main Housing Bores Align Honed
Block Deburr and Radiusing
Oil System Modifications
Balance Rotating Assembly
Rod Clearances Set
Rings Hand Gapped and Filed
Shortblock Assembly
davejonnes
United States
2017 Mustang GT350
Would you guys rather go turbo, TT, or SC? Which one would be more reliable with our engines?
soldier989
Columbus OH
2017 GTPP Premium
Superchargers are a bit easier on the engine with good gains. That's the way I would go, personally.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
The sc is easiest no doubt...but turbos will make a whole loe more tq
mustangv6magn
@mmagnetic2016
2016 procharged v6 magnetic 2016 ford eplorer
I think I'd sacrifice a bit of torque for engine longevity.
fordguys550
yep..."just" a V6
tehachapi, ca
2016 v6 6spd
A turbo isnt gunna be any harder on a motor than a supercharger...so long as its tuned properly
mustangv6magn
@mmagnetic2016
well that's good to know. I guess since I have always heard that turbos eventually go out especially if you do not do proper maintenance on them.
shadowsong6
2014 mustang v6
Yea it's pretty close to being cheaper to swap engines then it is to supercharge the V6..... I personally would swap in the coyote if I was going to do an engine swap.
not even close, procharger is cheaper by a LOT. yes, the price of the crate motor and the price of the procharger are close, but with the crate motor you've also got to factor in new wiring, new ecu, new exhaust routing, etc etc. You're looking at a 10k motor swap, easy.
zackmd1
Zack
When looking at a crate motor yes..... But take a stroll through eBay sometime... I can buy an low miles F150 coyote for around $3k. Drop $1k to upgrade the cams and intake to factory GT or even new 350 cams and intake. And then you still have about $3k for the trans and wiring. It can be done. Not with a crate engine but with a takeout.
The same can be said for the ecoboost now that the FR control pack is out.
S550 HQ
It really does depend on your build and application. We actually have done both. There like everything else are pros and cons. Both are going to require more attention from the owner. There is more maintenance involved with either.
Both do require spot on tuning, you are 110% spot on there. Either build can smoke a motor in 100RPM. Your tuner is the most important part of your performance equation.
kodypiccirilli
Arkansas
Kody
2015 Twin Turbo Mustang V6
Thats interesting! From what I know, the block and heads of the 3.5 are very similar to the 3.7. I believe the F150 turbo exhaust manifolds will fit our heads with minimal modification. After that, just need lines of the coolant and oil and the turbos are set.
Any idea if there are pre existing oil lines that can be tapped into to feed to the turbo? Or will we have to drill into the block and create one?
