Updated engine tear down video
Rubyred17
Kentucky
2017 GT350
Hello All
I hope I am not starting a war but I am
Really curious about something.
The young lady with the blown GT350 engine posted a video update of her engine disassembly and analysis of the failure. late in the video the failure appears to in one cylinder and it looks like the piston broke (or came apart) and those pieces scared the bore.
My question is if an aftermarket tune that allowed detonation could do that to a piston?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Hello All
Yes...but not likely. A good tune from someone like Shaun at AED or Lund isn't going to cause that. A ringland or oil-related issue likely caused it and had nothing to do with the tune. Proof? I know of many who had the same exact failure on a stock motor.
That said, a super aggressive tune from someone who doesn't know what they're doing could easily do that.
Rubyred17
Rubyred17
Kentucky
2017 GT350
so you are thinking that when the piston is removed the ring or land broke?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
A ring land failure is most often related to heat in this engine. If I had to guess, #8 wasn't getting enough lubrication with the oil, friction went up and then melted/weakened the piston enough for it to fail.
Rubyred17
Rubyred17
Kentucky
2017 GT350
Great explanation, thank you
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
I think she had a Lund tune in it actually. Go check out her youboob channel. She has lots of videos posted for her various mods (the car that is).
thill444
New England
20 SS1LE (sold 18 GT350)
It seems pretty consistent with other stock motor failures. Personally I think Ford should cover it, but I also get it. When you modify the car and tune it all bets are off when it comes to warranty work related to the motor.
Hopefully she will get the car back up and running soon.
JCSIX13
MA
Jack
2016 GT350
looks like she will need a new block or to have that block sleeved.
Hack
Minneapolis
Mustang, Challenger
Agreed. I wonder if they can do one sleeve, or whether they all have to be done. Either way $$$.
I was thinking the same thing as Honeybadger - too much heat and the ends of the piston ring pushed together and then it broke the ring lands. I don't know why though. Maybe it was low on oil or something? I would be surprised if low oil would do that to just one piston and still leave all the bearings looking ok. I would think the bearings would get hot more quickly than the pistons.
Maybe the tune was trying for too much power and it ran a little lean. It didn't really look like detonation to me, though. Just scratches from chunks of piston bouncing around in there.
Rubyred17
Rubyred17
Kentucky
2017 GT350
the other interesting thing was I did not see any scuffing from piston slap
Hack
Minneapolis
Mustang, Challenger
I'm odd quoting myself but I just remembered she didn't pull the bottom end apart. Maybe the bearings are trashed and on the edge of failure. That will be interesting to see.
schmeky
West Monroe Louisiana
David
2018 Mustang GT, 2024 Mustang GT
On most modern hi-perf engine failures of #7 and #8 are almost always the ones to let go. They are the last to get the coolant flow, which has been pre-heated by the other cylinders. So these cylinders run hotter and will usually detonate first. There were bits of melted piston in the dome = detonation.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Fun bit of trivia - the pistons are numbered differently than most think in the Voodoo due to the firing order and FPC.
schmeky
David
Honeybadger,
Thanks for setting me straight. I did reference "modern engines, but you are correct nonetheless.
Just curious if anyone has the info:
How does the PCV system work on the Voodoo as far as relationship with the intake and cylinders? Is there a mapping that one can view?
I’m only asking because back in the late 80’s early 90’s, Ford had an issue with the 5.0 Full Size Broncos blowing out cyls 4 & 8 due to the early design of the PCV system and how it was routed via the intake/cylinders. IIRC, this was a common failure point for the 87-90 MYs. Ford rectified the issue with a revised intake and where PCV was located or mapped for the 91-94’s. I have the actual Ford docs stored somewhere - because I owned both an 87 and 94....
I’m curious if such a PCV issue could cause a similar internal failure with the Voodoo?
