Tune question
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
I thought the same about "weeks."
Jaime: First, I hope you don't mind if I fail to use the @ moniker all the time, that gets tedious but I know it's helpful. Helpful UNLIKE these irritating forum ads that cause the page to redraw every time one of them changes size/clip. Grrr...
Secondly, I saw this morning that there are two factory grounds on the passenger tower, I hadn't seen the one under the brace before but I'm guessing that one is for the starter?
Anyway can you or anyone confirm or deny whether having my maintainer ground on the other tower ground is the same one as the PCM? As you can see, I used the #1 position but I don't think it would be a major PITB to move those two connections from one to the other.
Muchas gracias,
KB
A ground is a ground. Makes no difference. Just make sure not to hook it to the battery directly as that would bypass the monitor system. Keep it simple.
Tomster
Beware of idiots
Tom
What? Are you trying to tell me that your ground is better than my ground? :crackup:
The Chairman
South TX
I’m on firm ground when I say “YES!” :idea:
Unless of course, it a fiberglass Corvette. Who knows there a real ground in on those things....
Tomster
Beware of idiots
Tom
Former IBEW journeyman electrician here, and I do believe the chassis of a corvette is aluminum, right? Maybe not the best chassis ground, but you are right, its better than fiberglass.
The Chairman
South TX
The newer ones are aluminum. Older ones are steel with fiberglass body. My friend had a very nice ‘66 fastback with a 327, 4 sp. Looked awesome. But the electrical gremlins drove him crazy and he gave up and sold it (he actually traded it even for a new pick-up truck!). Couldn’t keep a good ground to the tail lights...
Tomster
Beware of idiots
Tom
The Chairman
South TX
Thanks, Don, me thinks I misunderstood Jamie's comment about the PCM/BMS "ground."
"Ground control to Major Tom..." 🎵 🎵
I was just commenting that #1 or #2 didn’t make any difference for the trickle charger. Both are chassis ground, just a few inches apart. :idea:
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Ground yes positive OK , better is to go to the battery . The computer systems monitor the negative side of the battery , that is why you want to be hooked to a body ground . So to speak down stream from the sensor
I thought the amp sensor was on the center positive terminal in the fuse box.
If you look at that wire it runs through a loop that looks like an am-meter shunt.
protraxduner
OK
2020 Shelby GT500 Race Red
The loop thingy is on both positive and negative cables.
5.Oh Crush
DMV
Ra
Mustang
Uhhh, have not driven in weeks? The battery will be quite low. You can get a battery maintainer for less than $40. If you brick your car you would pay many times that to resolve.
Do it right or don't do it. Flashing the ECU is nothing to trifle with. Also, draining even a new battery below about 11.9 volts is bad ju-ju and will ruin the battery. Car batteries are for starting, not powering the accessories.
Thanks.
I did kill the batter twice and it started up 30 minutes later. I did a reset last night. I will get a better charger to make sure its good the next time per Palm Beach.
I did not see a maintainer under 60$ at Adv. Auto. I will check Loes.
5.Oh Crush
DMV
Ra
Mustang
Oh, I start it up every few days and pull it out of garage and let run 5-10 minutes. Just not drive anywhere.
