Trouble finding oil filter
Alain
Alain
Northern NJ
Alain
2016 Challenger Hellcat / 2019 350R #413
i just called 3 of my local dealers and they all had FL-2087 in stock. all have them at list price $38.51 although they usually give 10% off if i ask for it. try your local dealers.
You’re out in California right? If my dealer falls through I’ll reach out to one of yours.
cantdrive55
Northern California
www.instagram.com
19 GT350R, 96 Viper GTS
I reached out to Mobil1, AFE, and K&N to ask if their filter designs are based on FL-2062 or FL-2087...Mobil1 and AFE said theirs are based on 2062. Mobil1 told me flat out they do not offer a filter application for the 2018+ GT350 AND GT500. Based on the initial responses from both, I don't think they were even aware of the difference. AFE said they're looking at designing an application for the 2087 design.
It's been over a week and K&N hasn't answered.
I'm sure any of these would be no worse than using a 2062. If I needed to change my oil now and didn't have a 2087 filter on-hand, I'd likely opt for the K&N based on the design. HP-7037.
galaxy
St Louis
'17 GT350
Don’t forget Amsoil has the correct oil filter also. Yes, it technically crosses with the 2062 (for look up purposes), but as others have stated, a high quality filter that will pose zero issues. Even though the only concern is the collapse issue, the Amsoil filter will already have a media like the 2087 and was most likely already superior to the 2062.
NDALLAS40
N TEXAS
2016 GT350
Anyone else having an issue finding oil filter
FL-2087?
looking to do my oil change before putting the car away for the winter and I can’t find it anywhere.
plus, the prices I’ve seen seem kind of high to me compared to last year.
ROCK AUTO
alan0614
Granite Falls, NC
Alan
2017 GT350 Oxford/Blue
Rose City R
Portland, OR
David
1963 1/2 Ford Galaxie R code, 2020 GT350R, 1991 Mazda Miata SE
Are there any aftermarket cartridges that have a metal frame internally? That would be one to have instead of the 2087.
cantdrive55
Northern California
www.instagram.com
No, not a single one does. The K&N appears to have a plastic reinforcement tube, but they haven't answered my request for info, so I can't confirm.
The Chairman
South TX
‘09 GT500KR & ‘16 GT350 Track Pack & ‘20 GT500 HP
I have both versions of the K&N Filter and don’t see much difference:
Inside, they look the same:
In both cases, the liner is plastic. The only difference I see is that the PS-version comes with black “O” rings while the HP-version comes with red “O” rings.
I’ll keep using either as they work fine in my GT500.
bplow33
New Hampshire
2019 Ford Mustang Shelby GT350
bcuz the 2087 is the new superseded metal internal 350/500 filter. I have 5 if anyone needs one
Hold on to what you have. You can't find the FL-2087 anywhere and I'm not sure I trust using the K&N HP-7037. It's crazy right now, even the dealerships can't give me a direct answer when they're coming back in stock.
The Chairman
South TX
I’ve been using the K&N for years on track. Not sure why you don’t trust them?
The Chairman
South TX
If you were desperate would you trust using the K&N HP-7037 or Amsoil filter on a 2019 GT350?
I’m not desperate and that’s all I have used since I got the car.
All my miles are on track or to/from a track.
bplow33
New Hampshire
Ok well that's at least good to hear. Are you using Motorcraft 5w50 or Amsoil? Also, I shouldn't say I don't trust K&N or this model filter, it's just that the FL-2087 is lined with metal where the K&N is plastic. I have no idea if that really makes much of a difference but I assume Ford makes them that way for a reason
The Chairman
South TX
The K&N filter is very sturdy. Not sure why Motorcraft updated theirs, but that’s fine too. There was a rumor of collapsed filters but turned out to be improperly installed filters that got twisted and crushed. And that was a factory install.
I only use Castrol 5W50 in my cars (not trying to start another “oil” thread). Just responding to a question.
I know OEM recommendations are meant to meet their minimum requirements. But I always go a bit better.
bplow33
New Hampshire
Also
The K&N filter is very sturdy. Not sure why Motorcraft updated theirs, but that’s fine too. There was a rumor of of collapsed filters but turned out to be improperly installed filters that got twisted and crushed. And that was a factory install.
Awesome, thanks for the info!
