Track mode enable button as built data for sync upgrade
thet33
Dallas, TX
2016 Magnetic GT/6MT/3.55
Very excited to try this once I get my unit installed. This is one of the main things I regretted about not getting the Premium.
stang1971
kcmo
2018 Premium Plus Magnetic GT
will the premium toggle switches fit in the base location? They look the same size..
Dirtyblueshirt
Award Winning Taste™
Anaheim, CA
Aaron
2022 Ford Ranger Lariat Tremor
If you're talking about the switch assembly, technically yes... if you mean the switches themselves, no - they are narrower as the premium has 4 switches versus 3 buttons in the base.
Someone may correct me, but I think the switch assembly is also tied into the circuit board on the radio panel, so you can't have premium switches with a base head unit.
[email protected]
florida
Nick D
red gt auto
You need the bezel and the circuitry inside it. A premium bezel will fit a base car.
[email protected]
florida
Nick D
red gt auto
Although there's a member here that 3d prints toggles for the base.
soldier989
Columbus OH
2017 GTPP Premium
That's correct, the buttons are part of the stereo/HVAC circuit board, at least for the base model.
stang1971
kcmo
damn....was hoping to keep the base bezel but able to have the premium switches......
Dirtyblueshirt
Anaheim, CA
Aaron
[email protected]
florida
Nick D
red gt auto
[email protected]
florida
Nick D
red gt auto
So guys...... I think I just enabled Drive Modes on the V6!!!!! :D:D:D:D:headbang::headbang::headbang::hail::hail::hail:
Following the AB data in the OP produced a compatibility error in both the IPC and ABS on my vehicle. I proceeded to go through an AB data dump of a 2015 EB premium looking for the data lines in the OP. This is what I found and what "seems" to have worked on my vehicle. I would imagine this data would work for any 2015 V6 or EB with the premium radio bezel installed.
IPC
720-06-01: 6C7F - 8000 - 18B1
ABS
760-02-02: 0200 - 117E
Did you have to use different codes because of you having an auto vs his manual or because of his being a gt and you a v6? Ive got a 16 base gt auto and i want to give this a shot tonight!
[email protected]
florida
Nick D
red gt auto
mustangmike86
fl
2016 mustang gt PP
Yes , if they dont work they are going to give you an error code. Have you tried the values i original posted to see if those would work?
[email protected]
florida
Nick D
red gt auto
4th toggle is active! WOW! I used the values from the 16 models I posted above!
thet33
Dallas, TX
Does your gear ratio have any bearing on what value to use or does it just correlate to engine (cylinders)?
