Track mode enable button as built data for sync upgrade
mustangmike86
fl
2016 mustang gt PP
Zach thank you very much, it works great now. I cant tell you how much i appreciate that, ive been messing with that for a few weeks now trying to get the right code, with no success. Thanks again
zackmd1
Zack
No problem at all! Thank you for the help on the drive modes!
Dirtyblueshirt
Award Winning Taste™
Anaheim, CA
Aaron
2022 Ford Ranger Lariat Tremor
When you shift to "S", does it change your selections to "Sport", "Sport+", and "Track" as well? I would think so, but just to make sure...
zackmd1
Zack
Just confirmed! Shifted into S and the menu went from 4 options to 3. Sport, Sport +, and Track.
zackmd1
Zack
Does enabling it actually make a difference driving??
Can absolutely confirm a difference!! Just went for a test drive! When in sport + there is a marked increase in throttle response and a change in transmission behavior. The auto trans in sport + is far more aggressive then in normal drive mode but not as aggressive as when I actually shift into S. It will hold shifts longer and is more eager to downshift based on throttle input but will still shift into 6th during normal driving unlike when in S. Track mode feels slightly more aggressive but not much of an improvement over sport + except for the removal of traction control. Snow/wet did not feel any different then normal mode??? I am assuming that this mode just turns up the sensitivity of stability control?
zackmd1
Zack
This is awesome.
What's the chance I can put a 15-16 MFT in my 17? Sync 3 is way over my audio budget after I bought headers and exhaust lol
Should not be an issue! The only thing I would worry about is the GPSM.... 2015 models had a built in GPS module that sent GPS data over Can Bus... I do not know if base model 2017s still have this module. I would assume so since this module is also responsible for the compass and since the base sync system has not changed from the 2015s.
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
did you have to add a premium cluster also to make it work
zackmd1
Zack
No, I just reprogrammed my base cluster. The only hardware modification needed is the premium radio bezel for the 4th toggle.
Kahboom
Kahboom
Cathedral City, CA
so the Base radio cluster would work if you just add the bottom switches from a premium cluster?
Lein
Willow Springs, IL
2015 GT PP
Awesome find all around. Finally have an excuse to pick up one of those MX bluetooth boxes.
zackmd1
Zack
Unfortunately no. The entire bezel will have to be replaced which will also require an MFT or Sync 3 swap.
Kahboom
Kahboom
Cathedral City, CA
so you need the premium Center benzel. now the premium Benzel is not directly Plug and Play with the base cars is it. I'm just wondering if you could reggae tomtop unit with a premium Center Benzel.
zackmd1
Zack
You most certainly can use the premium bezel without MFT/Sync 3. The question is how or if your climate controls will work. I do not know how well the premium bezel will play with the Tomtop in terms of climate.
