Tow hook install
tj@steeda
Timothy
DarthMalice
Huntsville, AL
21 Mustang Mach 1 M0960; AT; Fighter Jet Gray: SOLD 16 GT; AT; Comp Orange
I got the fog light overlays from Bemaro FIlms and went with the 'wet' approach to applying them.
Necro post but I am about to add those fog light overlays to mine...what do you mean by "wet" approach? I have seen the install video.
Rev68
South Dakota
2021 Mach 1
Spray with distilled water and it allows you to slide it around into position. You then need to use heat/squeegee to get the water out.
In hindsight, I'd just go with dry application and be sure not to stretch it too much as you put it on.
mallaki
NC
Peter
2023 Ford Mustang Mach 1
subbu7
Pennsylvania
Subramanya
mustang gt premium 2024
Hey Ron - get another the factory cover - MR3Z 17E811 A - and it only comes black, unpainted. No color match from Ford ? Removing the OG cover takes patience as it’s attached with an hook style anchor that needs some fiddling to remove. I installed the ZL1 main shaft with the LH threads, took some exact measurements & drilled the 1/2” hole with a step bit In the plain black cover. I later opened the hole to 9/16” to accommodate a sleeve to give it a finished look. Used blue loctite to assemble the hook eye with jam nut. I’m keeping my OG blue cover unmolested. Only wanky issue is ZL1 uses a RH thread for tow eye/jam nut making it a cumbersome procedure to tighten it all up. If they would have used a LH thread, it would be straight forward. Hope this helps.
Hi can you provide, where to buy, and what all color options( is red color available?) and also does the tow hook comes with the black cover ?
DRAGOON
Wisconsin
21 Mach1 HP VB
subbu7
Pennsylvania
Subramanya
Flyhalf
www.youtube.com
Alessandro
Im switching to a mach1 front bumper. So I might go lighter with a tow hook on the oem crashbar.
Do you guys have the part number for oem crash bar of the mach1 ? Is the tow hook in same location of 350 crashbar? Or gt500?
