Top speed from factory
Rugerman1
Nebo,NC
Terry
GMCSerria
What is top speed from factory on GT prem
I Bleed Ford Blue
North East OHIO
I heard they were top speed limited to 155 from the factory, regardless of final drive ratio or transmission.
Nickel
NC Twisties
www.instagram.com
Nick
2022 Mach 1 Handling Package TR3160 w/Recaros
I have a GTPP with the 3.73 and mine did 156 officially at the top of 5th. If I would've had the room, I could've went to 6th and could've done way more but 6th is a dog, even over 150...and I like my point free license.
Rugerman1
Nebo,NC
Terry
GMCSerria
Understand abt license
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
I did 157 but I think it still had more to go.
This is while at was on the dyno 😒
Deleted member 35775
Guest
i made it to 156 and the governor kicked in... i'm stock, a staggered setup with a Borla crossfire X/H pipe.
m3incorp
Georgia/Colorado
James
It may have more to go but once that speed limiter kicks in the....go stops there.
RasJeremy
Denmark
Ras
Mustang 5.0 2020
Even though my EU specs on the car says it is limited to 155mph I have been able to hit 165mph on the highway.
I have stock 19" wheels, open filter and x-pipe but afaik the car is electronical limited which I don't understand I can exceed like that.
Cajunrice
Miami
Anthony
2019 Bullitt
GT 155 electronic Bullitt 163. Yes, a tune will remove/increase top speed. I can do 170 without any issues.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
a tune takes way the limiter...
WD Pro
United Kingdom
Lime GT
I thought that was the first limiter, and then there is a second (higher) limiter tucked away in some other module somewhere ?
WD :like:
