Tire fitement (Square setup advice)
Pierangiolo
Miami
2019 Mustang GT Manual (sold), 2020 Mustang GT A10
I am planning to do a square setup on my 2019 mustang gt. I was planning to do a square/flushed setup with my car (where the car tires aren't poking or tucked inside the fenders). The only mod I currently have are Pedders extreme coilovers (If you are wondering how they are, they change the way the car feels completely).
1. The issue I have is that it looks like the car cannot have a square/flushed setup because the rear track width is much larger than the front track width meaning that if I stick a 19x11 tire, the rear will still be slightly tucked if both tires are the same offset (can somebody confirm this for me).
2. Does anybody know if I can find some proper dimensions of this vehicle. I want to know the distance from the brake disc to the fender of the car for the front and rear of the vehicle so I can properly get a flushed setup (I dont want to look at pictures and "guess"/ I also don't want to stick any spacers)
3. In the case that I have to "guess", do you guys think a 19x11 wheel would fit in the front without any spacers and rubbing(I know it will fit in the back but I want a square setup) knowing the fact I have the coilovers. I dont want to throw some crazy camber just to get it to fit.
Worst case scenario I will run a 19x10 and get a 285 tire and call it a day. Ideally I want to run a 19x11 and do a 305 square setup without the need for spacers and massive camber.
I appreciate any advice or help you guys provide for me.
Thank you.
opengl
PA
2018 GT PP1 400A 6MT
+1 for 285 square
Ecoboosted
A state in the South East of the US
18' Mustang GT, 19' Road Glide
I have 19.5 with 275/40ZR19 squared and it handles and looks good. Same rear size tires and wheels on the back of a PP1 on all 4 corners.
86pagt
Virginia
Dale
2019 Ford Mustang GT
I have 19.5 with 275/40ZR19 squared and it handles and looks good. Same rear size tires and wheels on the back on a PP1 on all 4 corners.
What size spacers are you running
Ecoboosted
No spacers. They are RTR wheels from American Muscle. I’ll take a picture tomorrow during the day light.
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
There's no way to run 19X11's (with 305's) up front without one of the three:
Poke (induced by spacers)
Serious camber
Even more serious rubbing
This is my 285 square setup:
Not "hellaflush", but not hella tucked either.
What's your offset, im assuming you have 20x11?
+1 for 285 square
What's your offset, what size of him?
opengl
PA
DonnieO
Donnie
2017 mustang gt cs
19x10 here. +35 275/40/19
You cannot do a 19x11 in the front without a spacer and a good bit of negative camber.
Ecoboosted
Not as wide as other people’s set up but it’s good for my driving style and squared for rotations.
ModularKid21
‘15 GT
If rotating isn’t something you’re worried about, you can always stagger offsets. 19x11 +27 up front and 19x11 +50 (or there abouts) will get you the fit you’re looking for with the clearance you need.
Below is my car with 285’s on 19x11 +52 and a 20mm spacer. The clearance is so close to the strut, you couldn’t go any wider. I’m currently running -1.7* camber up front. If I had 305’s, I’d need at least a 25mm spacer which has been done many a times on this site. A 19x11 +52 with a 25mm spacer gets you an affective offset of +27. Enter Apex’s non rotatable square set up
Pierangiolo
Pierangiolo
Miami
