thet33
- Nov 19, 2015
- Dallas, TX
- 2016 Magnetic GT/6MT/3.55
Do we have a weight on the spare tire kit? Scanned a few pages but didn't see it.
On my GT350 I removed the rear seat and installed the GT350R rear seat delete and lost 35 pounds including the rear seat belts.Just weighed my car.......3,520 LBS with 1/4 tank gas
Here are specs for those interested (listing only the items relevant to weight saving):
Base 2015 300A GT with ZERO options
Forgestar CF10 11x19 on all four corners with Yokohama 305/30-19 tires
Sparco EVOII seats in the front and stock rear seats still in place
Removed front stock seat belts, rear still in place, Sparco 4 point in front
Aluminum hat front Brembo brake rotors
Stainless Works full system, no cats
DSS aluminum drive shaft
DSS 800hp half shafts - added weight
Removed sound deadening in a few places, like felt under carpet and hood liner
Anyway, I was hoping to be under 3,600, so I'm really happy. Only 20 lbs to go to get under the 3,500 lbs mark. To get there I still have the following options:
Rear seat and belts delete
Remove trunk liners, carpets and electric tire pump
Front washer bottle delete
Maybe Watson racing crash bars front and rear
Thinking about the Anderson or Tiger CF hood with vents
Lightweight battery
And I got an Aluminum flywheel sitting in the garage as well
Anyway, as you can tell, I'm really happy to be so close to 3,500 lbs :cheers:
:hail:Just weighed my car.......3,520 LBS with 1/4 tank gas
:cheers:
Lightweight battery
Yeah, I didn't list this in my description, but I have Cortex offset struts in front. The offset struts give you another 1/2" inboard clearance AND also save weight. I also have coil overs in the rear that are lighter than stock.How do those 19x11s fit? Can you share if ya had to do anything special to get your setup to work?
Good info.3 inch Corsa Sport cat back single tips
Mufflers 17lbs 14oz each (2)
Adapters and clamps 5lbs 6oz
Tips (2) 4lbs 11oz
x pipe 15lbs 6oz
61lbs 3oz total
Tips (2) 4lbs 11oz
x pipe 15lbs 6oz
61lbs 3oz total
Added a Corsa Sport axle-back this weekend.Good info.
