sldghmr
Yup, we cut the bottom of the spare tire well out...and the charcoal canister is history. My old car had air ducted in from outside and the cooler was in a sealed case/covering so every inch of air coming down that tube went directly to the cooler. Set up came with the car, and I was not smart enough to put a temp sensor somewhere along the setup to get readings :doh:Well I would rather see the cooler outside the car, did you cut out the trunk under the cooler and relocate the charcoal canister from under the car? You would then need to push the air through the coolers with the fan and out the bottom of the spare tire area to under the car. Another option is to duct air in and out of the tire area. Without getting the air out of the trunk you will heat soak the air in the trunk as it is recirculated through the coolers. That setup will add a lot of ambient heat to the interior of the car even with block off plates.
The fan and cooler will be fine as far as size goes, the heat load from a manual trans is not that bad and the diff is not that much either. If you can setup the pump and fan to run on a thermostat with the key off or from a manual switch on the dash that would be best. You want the pumps and cooler fan to continue to run after the car is shut down back in the pits and keep running until the min temp is reached. Most of the setups I have seen will run 3-5 min after the car makes it back into the pits.
Going with manual dash switch for now (we're in the 'just get it running/moving' mode right now), later would like to add thermostat or timer. I'll be sure to run them 3-5min upon return to the pits....Thanks!!!:cheers:
