Surging throttle
SnakeMaster16
Miami
Giovanni
2020 Ford Mustang GT Premium PP1
If the car is under warranty take it in. This issue stems from a defect in the head itself, none of which would be attributable to the air intake changes you made. It does apply to a narrow range of build dates, 9/1/2020-12/1/2020 if memory serves. Look at your drivers valve cover sticker for your engine build date.
Okay I will definitely check the build date. Anywhere I can see the TSB or what ever was sent out officially by Ford on the matter? Thanks
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
Sorry for the lack of any updates here. I’ve been trying to get this thing fixed since June, and I’m now on my second dealership. These fools can’t diagnose crap, and when they do they order the wrong parts, then when they get the right parts, they don’t have the manpower to fix it. Second dealership took 3 weeks to get an appointment, and when I took it in today lo and behold they couldn’t diagnose because there is no active check engine light. Stored codes aren’t good enough. Frankly I’m getting fed up with the $hit service out of anybody these days, and I’m about ready to set this POS on fire. Once I get a resolution I’ll post it here. Opened a case with Ford to try to get it fixed, they are about as useful as tits on a bull.
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
Car is in the shop this morning. Hopefully this issue is resolved by end of week. I’ll let y’all know.
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
Have the car back after 8 days. They replaced the cylinder head, and it seems to have solved the issue. I’ll post a pic of the repair sheet later for those that are interested. Thanks for following along!
Conman1138
Durham, NC
Connor
2018 Mustang GT PP1 6MT - Ruby Red
That's great news! I'm glad a solution was found.
Did your dealership techs have any theories as to what the cause of the problem may have been? When I had my engine replaced for this problem, the dealer techs theorized that it may have been a defect in oil passageways causing surges of oil pressure to reach the intake cam phaser. My old engine went back to Ford for a teardown, but I never heard anything after that.
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
They didn’t offer any opinions, however, the SSM bulletin mentioned a “flatness issue” on the mega cap. To me, that says there was a machining issue with a certain batch of heads and the caps were not square to the heads. When torqued down, they probably let oil pressure escape where it shouldn’t, which caused the VCT to shift when it wasn’t supposed to. This seems likely, since certain times while driving the car would feel way down on power until 5k rpm, at which point there was a huge surge in power. My thinking is the oil pressure retards the low rpm timing, and it defaults to the high rpm timing when pressure isn’t high enough? During those episodes it also idled like it had a cam in it, very lumpy and rough idle. You could literally see the movement if you looked at a fixed reference point.
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
I wonder how they determined it was a head issue. Meaning, ok you have a cylinder down on compression (just assuming) or maybe valve blow by (bad seating valve) I guess leak down?
As mentioned in the SSM I don’t believe it was a valve sealing issue, more a VCT problem with the timing. The codes I was getting pointed to the cam sensor on bank #1, exhaust cam so that likely was the solenoid that was unstable due to fluctuating oil pressure.
Conman1138
Durham, NC
Connor
Very interesting! Now I'm wondering if a head replacement would have solved it for me, too. My dealer went straight from replacing cam phasers to replacing the whole engine on recommendation from Ford engineering. Maybe they knew less about the cause of this particular issue 3 years ago.
I bought my car used, but I got to break in the new engine myself, so it worked out in the end!
Interesting result and findings. I say that because I actually posted the SSM 50103 back in December 2021 - but never wouid have guessed that was the actual issue for your vehicle.
If anyone needs it, here is the SSM for the mega cap issue:
https://www.mustang6g.com/forums/th...flatness-on-mega-cap-rh-cylinder-head.169407/
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
Unfortunately the saga continues, the car had an oil leak where the timing cover meets the oil pan. So after 8 days in the shop, it’s been in there another 2 days. They tell me it should be done tomorrow. I don't think I have to say I’m beyond frustrated with this, and even as a lifelong Ford guy I don’t think I’ll ever buy another one new if this is the level of service I should expect. Never had an issue pre-Vid, now it’s like herding cats trying to get this effing thing fixed.
TW Merema
TW Merema
Mobile, AL
TW
2020 Mustang GT
Car is back, took them 3 days to correct the oil leak, it was where the front cover meets the oil pan. If anyone else has this repair done make sure you check that spot for oil leaks. It drips right on the steering rack control box, then down into the belly pan.
Mike-S550
2018 Ford Mustang GT
So, you’re saying it wasn’t the cat back? /s
Glad you got this sorted, op.
Conman1138
Durham, NC
Connor
Man, I really hope this is the end of the problems for you!
FWIW, mine has been rock solid reliable since engine replacement for more than 30k miles now.
