Surging at 3100 rpms
2017RoushStage3
Germany
2017 Roush Stage 3, 2006 Saleen SC
I am trying to figure out a surge at 3100 rpms. I can really get it to surge dropping down through 3100. Doesn't do it at any other rpm but will do it in just about every gear. Lund says it is a "throttle" issue. I tried switch back to the stock TB (running a vmp ) but it does the same thing.
It has all the upgrades, injectors 79mm pulley PMAS CAI etc. Drives fine otherwise. Not sure where else to look?
2017RoushStage3
2017RoushStage3
Germany
Anyone? I am thinking tune but Lund thinks otherwise
Usually the "surge" can be associated with a failing (or failed) IMRC or throttle body.
Has there been any codes or have you tried to extract any?
2017RoushStage3
2017RoushStage3
Germany
I swapped out the vmp TB for the stock tb and nothing changed. Which I would think would eliminate the TB being the issue.
will double check that there are no codes (no check engine light illuminated)
2017RoushStage3
2017RoushStage3
Germany
Actually is a code p115e. Tried clearing and it just comes back.
I cleaned the tb when I had it off. Thoughts?
I know you have said you have replaced the TB, but the code you are getting is:
Throttle Actuator Control (TAC) Throttle Body Air Flow Trim at Max Limit
Also make sure the O-ring (if present) has not been damaged or is not missing. Replace if necessary.
Remove the TB and give it a really thorough cleaning. Also be sure to use cleaner specified for cleaning EFI throttle bodies; do not use any carb cleaner!
Reinstall and make sure all connections (wire harnesses) in and around it are secure.
Before starting the car, try clearing the code again. If you can't clear it the way you are trying to, start the car and see if the code goes way. If it does not go away by your means of clearing it, you may only get a solid clearing of the code if you disconnect the battery and let it sit for at least 15 mins.
If the above does not work, check out this thread - although not S550 related, same code on a S197 GT500 w/VMP add-ons and good tech info:
https://www.fordgt500.com/threads/p115e-fault-code.190785/
2017RoushStage3
2017RoushStage3
Germany
Tried a thorough cleaning, cleared codes and immediately at start up the code came back.
Reading through the article seems to me the issue was resolved by a tune revision.
I really appreciate your help. I will contact Lund again with this code and hopefully they can resolve it.
Hey no problem. Hope something works out for you; post updates when you have them.
beetle6986
Harrisburg
16 Mustang GT, 04 Cobra, 2008 BMW 335
Did you ever figure this out?
2017RoushStage3
2017RoushStage3
Germany
Still working with Lund. They have been able to clear the code but the surge is still there. Just got another tune to try but it has been raining and not able to take it out just yet. Hopefully tomorrow.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
How long did you have the lund tune before this issue started?
Re-flash the roush tune, does the problem go away?
2017RoushStage3
2017RoushStage3
Germany
I just bought the car. Previous owner said it has been happening for a bit. Doesn't recall when it started though which makes it really difficult to know what part may be causing the issue
K4fxd
NKY
I'm assuming you don't have the roush tune then?
Is there a stock file on you tuning device. If so flash that and see if the car starts and idles. If so watch the AFR meter in the dash, make sure it is bouncing around 14.0
If that checks out you probably have the roush tune. Drive it. Don't get on it. If you don't get a wrench light in about a mile you should be ok to test for the surging. If it goes away it is the tune. If not it will need to be looked at by a mechanic who knows mustangs.
Avispa
Oldsmar, FL
Richard
2016 Mustang GT/CS convertible
I have a similar VMP set up, right down to the 79mm upper pulley. Got the p115e code a couple months after I bought the car, and yeah, the throttle body was filthy. A good cleaning fixed that. I also had the surge a light part throttle. You could see the tach blip about 50 rpm. It was the tune. It took a few tries, but tuning finally fixed it. VMP did mine.
2017RoushStage3
2017RoushStage3
Germany
I am really hoping it is just the tune and Lund can figure it out.
I don't have the stock Roush tune just the Lund tunes.
Another revision from Lund but no change.
They said the surge was driver induced...so this time set the cruise and datalogged it...
