Stock clutch durability?
troverman
NH
2020 Mustang GT Premium manual
I'm curious how durable the stock clutch in an S550 GT is. Is there a difference between the 2015-2017 and 2018+ models? Can these clutches stand up to burnouts or hard launches? I am well aware that, generally speaking, abusive use will eventually destroy any clutch but I'm curious what people's opinion of the stock clutch is. My car is only a few weeks old with 800 miles on it, so I have very little experience with it.
Dfeeds
Illinois, US
No idea how durable but the 2018+ uses a twin disc clutch and a dual mass flywheel so it's quite a bit different than previous models.
silverbullet85
San Diego
2019 Gt
Stock power levels it should last a very long time as long as you aren't a moron. The 2015 to 17 are a single disk and the 18 and up are dual disk but both clutches are junk as far as shifting the car above 6000 rpm.
Shifting_Gears
South Florida
Plenty of reports that the stock 15-17 GT clutch is hot garbage. 33k on mine and already having slipping. I drive my car way more conservative than many others.
Dfeeds
Illinois, US
Probably why they upgraded the clutch in 2018.
EmCel
VA
Em
2016 mustang gt
I'm almost at 55k miles in a 16 gt and haven't had any slipping issues.
The only problem I had a couple of times was it wouldn't go into 1st gear but on second try it did without a problem. It hasn't happened since then.
I'm aware that it will go out eventually but for now it seems fine and shifts fine. Thank God 👍🏻☺
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
40k on mine and it clamps down harder than a crazy girlfriend trying to get pregnant. Anyways the 15-17 they can handle around 600 wheel without a problem. Of course its service life will drop at that level.
cop on my back
Victoria, BC Canada
2022 Mach 1
From all the posts I have read on failures and my own personal failure, 15-17 clutches fail from high RPM shifts, north of 7000. Clutches work perfectly fine and then for some reason, usually at the worst time, when you push in the clutch for a high rpm shift the centrifugal force pulls the friction material off the clutch disc as it is no longer squeezed between the pressure plate and the flywheel. After that happens you have nothing but a tow coming your way and a bill.
Red65
MS
Red 1965 Coupe, 2017 Premium MT GT
slipping at 33k?? I'm almost at 51k and I have no slipping. Mind you I have beat the socks off this car, and I taught 2 people how to drive stick in it.
Shifting_Gears
South Florida
Yeah, it’s shameful. I truthfully don’t hammer the car that hard. I have fun with it, but RARELY do any hard launching, never power shifted it, no sticky tires, etc.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
High RPM lockouts are from the body mounted shifter, not so much the clutch (although occasionally it can actually be the clutch). Get a barton or MGW and call it a day.
Hbassi5
California
Hardeep
2019 Ford Mustang GT
My buddy traded his 2015 Mustang gt with 83k miles on it. Never had issues with clutch.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Just replaced my '16 GT's clutch at 72k, clutch looked fine actually, good life left in it. My issues was the slave cylinder inside it went bad.
I don't do burnouts, but I have plenty (hundreds) of hard launches.
BMurphyTN
Nashville TN
Brian
2017 Mustang GT PP, 2015 Harley Streetglide
This is exactly what happened to me. Failed at 26k miles on a high rpm shift to third.
shogun32
Northern VA
the question is does a 18+ clutch pack bolt up with no/little effort to a 15-17 car?
