Steeds clutch spring
lockwood
Canberra Australia
MY2019 Bullitt, 2018 BMW M2, 2019 MX5 RFGT
Has anyone fitted the Steeda clutch spring to a Bullitt.
Apparently the factory Bullitt spring is a lot heavier and has more coils. I’ve tried compressing it with long nose pliers, but I can’t.
Any suggestions?
TLW1022
Coconut Creek FL
Terry
2019 Bullitt K3464
Any suggestions?
I believe all GT's & Bullitts have the same spring
I did mine, you have to use needle nose ViceGrips to fit in between the coils, I had to fight with it a bit, maybe because I'm left handed
Move the seat all the way back, I used a pillow on the door sill so I could lay on my side to get both hands up there. I have seen some that have a person sit in the seat to push the clutch pedal in for you
There are a couple videos on YouTube where they just pull it to the side sliding off the bottom, they say it may brake the lower saddle.
Schwerin
Home
2019 Mustang
I'm personally wondering if the new 2019 GT350 clutch peddle can be easily swapped. It's completely redesigned, and supposedly feels better.
aileron
Montana
Dick
'19 Bullitt K1191, '20 BMW X3 M40i, '17 BMW 440xi, '14 Ram truck...and 19 old Triumph motorcycles
I'm really happy with the stock Bullitt set-up AFTER swapping in the Steeda spring and perch; it was Delta Sierra prior to the swap - really weird clutch feel.
OvalBlue26
Arizona
Kenny
2019 GT Bullitt
Any suggestions?
Any suggestions?
I debated buying just the spring but opted for the Steeda perch too. Glad I did because I broke part of the retention lip off the stock flimsy perch taking it off. I like the new feel even though the stock feel was good too. It’s just a more linear feel through the clutch stroke now.
slammer223
Missouri
Donald
2019 Bullitt, 2017 Mustang GT convertible
I used a short length of wood to keep clutch depressed and needle nosed vice grips to remove the spring on my Bullitt. Putting in the Steeda spring was a 'snap.'
GreenS550
Houghton, MI 49931 Oakland, MI 48363
Bob
2019 Mustang GT Premium 2020 Explorer Limited
I bought the spring at the same time as the tune. Since the car makes more torque down low, clutch engagement became much easier.
Then put the Steeda spring in. I might remove it as I like city driving sometimes and do not like the increased pedal stiffness at every light. I am also not a fan of the looseness at the top of the pedal.
TLW1022
Coconut Creek FL
Terry
2019 Bullitt K3464
Give it a few hundred miles, I drive @ 120 miles a day which has quite a bit of stop & go driving
I wasn't sure at first but like it now, I didn't like the Kick at the end of the pedal travel with the stock spring
s101
Chicago
2019 Bullitt
Any suggestions?
I just did. The clutch travel/feel was my biggest dislike on my Bullitt. This is night and day better. Replaced spring and perch. So much better. Feels like a sports car instead of a truck.
tj@steeda
Timothy
Think about what our other parts could do too :)
tj@steeda
Timothy
Blownfx
Lehigh valley
2019 Bullit
I think I depressed the peddle, got the tips of the vicegrips between the coils, left the peddle up while putting pressure on vicegrips(or they push out) and when coils closed I was able to lock the vgrips
Had to pre set vgrips for gap before starting process. Then I was able to wiggle spring out.
