Steeda Clutch Spring Alternative
Leigh_bullitt
Spain
Mustang Bullitt
Hey
I tried the steeda clutch spring a while ago and although it made the clutch more linear it was killing my knee in traffic holding it down all the time and went back to stock.
the problem is the return of the clutch. It literally just springs your foot up.
are their any products or ideas to help slow the pedal down a bit?.
I was thinking of adding a spring to the pedal that tenses when you release the clutch to not make it so hard.
you guys have any experience with this ?.
thanks
Leigh_bullitt
Spain
Mustang Bullitt
Thanks Buddy
Not quite what I’m looking for though.
I was thinking of getting a spring like the attached photo and fitting it to the pedal and somewhere else so it causes tension when I release the clutch.
Nightmonkey
Germany
Jens
2020 Bullitt
That is not how it works with springs...
Adding this to the Steeda spring is like choosing a stronger spring instead of the Steeda spring.
The only thing, that could do what you want is a damper, that has different behavior for bump and rebound.
Or maybe modifying the clutch master cylinder.
I would recommend to test the other, cheap springs from Sodemann before putting that much effort into it.
...and do the J&M clutch line, that's the most important mod for the whole clutch mechanism, not the spring.
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Nightmonkey
Germany
Jens
2020 Bullitt
@Mikepol2
I already tried to make this clear to him in 2023, but he didn't want to listen...
Will we both be able to change that this time?
Leigh_bullitt
Spain
Mustang Bullitt
Solved….
Thanks guys the problem was actually in the tune.
Yes the pedal is the same stiffness but the problem was the revs hanging too long. So changing gears the car surged because of the rpm’s and my foot was hurting trying to holding a specific spot on the clutch to not make it surge.
tuner changed something and also asked me to do a crank relearn with the clutch depressed.
all good
Smooth as silk now
thanks guys
Nightmonkey
Germany
Jens
2020 Bullitt
The spring will still make you tired the next time you get stuck in a traffic jam.
Leigh_bullitt
Spain
Mustang Bullitt
Yeh
I’m thinking of a stiffer clutch spring.
Factory is 185lb looking for one around 220-230lb would help a lot.
Nightmonkey
Germany
Jens
2020 Bullitt
You won't be able to install anything stronger than the OEM 185 lbs/in.
Your Steeda spring has 35 lbs/in.
It would make sense to use a spring force between OEM and Steeda (see the link above).
Leigh_bullitt
Spain
Mustang Bullitt
Don’t have steeda installed.
It was too hard so I went back to stock
Nightmonkey
Germany
Jens
2020 Bullitt
And stock is still not enough support?
Leigh_bullitt
Spain
Mustang Bullitt
To press the clutch down yes it’s no problem.
the problem is the pedal return. It springs back up with some force
Nightmonkey
Germany
Jens
2020 Bullitt
Still OEM clutch?
Strange thing!
GregO
Illinois
S550 GTPP
The heavy stock spring has caused the clutch pedal arm pivot welded sleeve to crack.
The best thing is to stretch out the Steeda spring (I have a post on this procedure on M6G years ago).
If stretching the spring isn’t a solution then I’d suggest hitting the squat rack.
