Steeda Clutch Spring Alternative
Leigh_bullitt
Spain
Mustang Bullitt
Don’t think theirs anything wrong with it.
It’s more just me not liking a harder clutch pedal.
Leigh_bullitt
Spain
Mustang Bullitt
The good news is that the tune and crank relearn fixed the clutch surging between shifts.
that was really pissing me off when low rpm cruising.
Been driving stick only for 33 years and looked like an amateur.
GregO
Illinois
S550 GTPP
The OEM spring is a clutch pedal depression assist, it lessen the leg pushing effort. So as mentioned in a few posts you need the intermediate spring to regain the assist. OEM spring was designed for females, Steeda spring is designed for near zero pedal depression assist.
Many guys take the spring out completely but with that causes an issue returning the pedal arm to activate the clutch switch.
Leigh_bullitt
Spain
Mustang Bullitt
Yeh it’s easy to press down the problem is the return it really wants to spring itself back up
Nightmonkey
Germany
Jens
2020 Bullitt
Can't remember this, no problem like this with my current Sodemann spring.
Jaymar
Portland, OR
Jaymar
2022 GT/CS - Rapid Red
There is often some confusion about how the OEM return spring works. I went with the 97# spring as mentioned earlier as a nice compromise between the Steeda nothing spring and super heavy OEM. While the return spring assists in holding down the clutch when depressed, it also pushes against you in the later half of the return travel of the pedal. There's a brake-over point in the travel where after you compress it, it assists you instead. So, a lighter spring means more force to hold the clutch in but less force pushing back against you as you let it out.
GregO
Illinois
S550 GTPP
Stretch the Steeda spring out to 3.25” to 3.50”
That was the sweet spot for my Steeda spring.
Leigh_bullitt
Spain
Mustang Bullitt
Didn’t actually think about stretching the spring out a bit 🤔
Nightmonkey
Germany
Jens
2020 Bullitt
Maybe get one of each Sodemann spring and find the best solution for you, like I did?
No need to try to alter the Steeda spring, there is something out of the box that fits your needs. 😉
Leigh_bullitt
Spain
Mustang Bullitt
Which spring type you went with in the end Nightmonkey?.
Nightmonkey
Germany
Jens
2020 Bullitt
Sodemann C16871772000M
GregO
Illinois
S550 GTPP
Sodemann wasn’t available way back in the early S550 days. So stretching was my fix back then. Took some effort to stretch it. There’s some risk involved too. Personal protection is a must.
Nightmonkey
Germany
Jens
2020 Bullitt
@GregO These are standard springs for the industry, they have been around for years, but noone except Steeda figured out. @Mikepol2 came up with it here in the forum, if I remember correctly.
McMaster-Carr is the source for the US.
Btw. Steeda offers 95 lb/in spring for the S197.
