Steeda Differential Install issue on driver side front bushing
Oakley
Lee
2022 Mustang
No need to get shook up, take a deep breath and pull yourself together.
oh look more emotional projection while i live rent free in your head from the looks of those tags.
whySoMad?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
whySoMad?
It's clear by every one of my responses that I'm simply trying to help you. You are not bothering me in any way. Logic has no feelings. I'm just here to help, Oak.
Oakley
Lee
2022 Mustang
look, random guy on internet, you're the one going around tagging me in unrelated threads to talk shit cause you can't work out your issues in that other thread. you're talking about feelings so much but you ain't gettin that from me so where they comin from homie?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Let's be real, we are both random guys on the internet. I'm not trying to work anything out. I'm just trying to help you out. I just want you to properly utilize the product you purchased.
Kobi Addiction
Houston, TX
2017 Ford Mustang GT350
It’s definitely a tight tolerance when installing the diff back into the diff bushings. I installed the hardcore bushing kit, diff bolt upgrade and support bracket which made it even worse haha. I had to get all 4 bolts threaded into the diff little by little all the way around. Nothing is impossible, but I believe the only way this can be done properly without you getting so angry you hit your dog is dropping the rear subframe to gain full access. I just dropped it from the start, it’s not very difficult, but have an extra pair of hands to help.
The diff clunking is normal between shifts, I get the same.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I spoke to our lead installer, this is what he has recommended:
1. With the car in the air enough to comfortably slide under it, remove the front differential bolt on that side (yes, I know, it faces towards the rear of the car). With the bolt out, run a 14mmX2.0 tap into the hole cleaning the threads as you go. This will repair any damage done to the threads allowing the front side bolt to be installed. Note, that it may be necessary to support the differential during this process.
2, Once the threads are cleaned, reinstall the rear-facing bolt and torque into place.
3, This is the hard part. Support the front of the subframe on a jack. Remove both front subframe bolts, and loosen both rear bolts(if you have any subframe braces, they will need to be removed). Lower the jack until the subframe drops 3-4 inches away from the body of the car.
4, Using a prybar, push the subframe towards the rear of the car. Take the bolt and washer together, and install them into the bushing. With the subframe pushed back as far as possible(this may require an assistant) install the bolt/bushing into the pocket. Thread the bolt in by hand as far as possible. Use an open-end wrench to finish tightening the bolt. This bolt only needs 25-30 foot-pounds of torque to be tight enough.
If you have any questions or concerns, you can email me directly & I can put you in contact with our installation team.
Many thanks!
Tim
I had the same problem - the front left bolt/washer/puck just couldn't seem to go into place to start threading by hand. And I used four 10-inch-long all-threads studs and nuts to temporarily drop my cradle by a few inches! Calling Steeda was no help back then, but I wish I had the above procedure available, because I hadn't thought about using the slop to move the cradle back by prying. (Which would also necessitate temporarily removing the CB005 kit.)
But this is the best tip:
... install the bolt/bushing into the pocket.
IOW, assemble the 3 parts together and then try to angle the set up into place to start threading. You can't put the puck/washer in place first, and then start the bolt.
Also, I don't see how there is room to run a tap unless the cradle is completely dropped, but I may be wrong on that.
Keeffa
australia
keith
ford mustang 2018 gt
Hi all,
I attached a photo reference to make the story telling easy on what I experienced during my diff bushing install yesterday. The result at the end was having to reinsert the factory bolt minus the bushing. In short I got 3 out of 4. It was dark and this took way longer than expected using hand tools. The result with the 3 are incredible considering I have most of the other suspension mods added on (sub frame alignment sleeves, braces, billet inserts, rear sway, vertical arms). The 3 bushings removed the flex the diff had resulting in a light clunk during lights shifts or throttling on and off in traffic.
Case in point, hoping to get feedback on the following
A) Anyone else go through this?
B) Any opinion of running 3 vs. all 4 from a structural integrity or risk perspective?
Thanks everyone!
P.S. I did speak to Steeda (Thanks to Rod who was helpful) but confirmed they had not seen anything like this from their experience.
-Nick
Sounds like the bush insert was not in properly may have been wrong insert or needed turning to slip into bush.
Did you grease the insert. I know very fiddly job I dropped the whole sub frame to do mine. Having only 3 in might load up the bolts more. I've heard some have broken the bolts.
Especially if supercharged.
DougS550
Fishers, Indiana
Doug
He did get a Little Salty on us: LOL. BUT: If it were me, I would follow the OEM directions for the install or have a shop do it, or not do it at all. But that's just me. Good Luck and keep us posted
Grinchoffl
Grinchoffl
Mia
2019 Mustang Bullitt
Ni
Nice setup and pics to back the detail. I won't get angry...those days are behind me....But i will get bourbon, which then makes me lazy, and then I prefer to work on the bourbon then the car... Priorities are not always in order!
Grinchoffl
Grinchoffl
Mia
To c
Hey Keefa....The bushing and bolt were fitted in...It was simply by turn 6 of the bolt the rotation of the bolt went into an angle pitch instead of straight through like my artistic pictures tried to replicate :) ....It seems I got enough direction and validation on what I suspected I may need to do. Thanks for being a great community!
Xgamex22
Ksa riyadh
Ahmed
Mustang gt premium none pp 21
Ok i lowered the gas tank with help of my friends to install the last one 😅😂
