Steeda CAI Review and Install Notes:
MyMilkshake...
United Kingdom
2016 M4 Competition & Tuned DS3R The Stang Killer
They look great!
Can you buy the kit without the conical filter?
How does the velocity stack hold up with heat soak?
Poppacapp
NC
2015 Mustang GT
They look great!
The stack I would assume dissipates heat pretty quickly being it is aluminum. I haven't noticed any issue while driving. Heat creeps up while stopped just like the stock airbox does. I was sitting in a parking lot the other day doing some stuff on my phone... probably 10mins of sitting, and IAT was at 148degrees... started moving and cooled down pretty quick.
Khyber
it's a hard parked life
Lexington/Myrtle Beach, SC
Landon
2015 GT PP CO
to be honest, steeda wasn't even on my radar because I wanted a painted jlt so bad if I did an intake...but after the pricing on the intake + tuner + tune on the pre bf deal, I started my research on it and all the good user reviews and it was worth a shot to try it out. Once you get it and see the builder quality, especially of the velocity stack it's awesome!
I'm going to paint the black tube though whenever I get around to painting the coils and engine cover though.
If you're on the fence and reading this thread, you should really consider the intake over the competition.
BBB
Potatoville
Premium GT Poverty Snack
Installed it yesterday... putting the box had me frustrated because I couldn't get the rubber piece in the bumper to line up.
Question
Have any of you had issue with fitment in the area circled below? I feel like the plastic piece isn't perfectly lined up with the aluminum tube the MAF sits in... It's hard to explain but it comes in at an angle.
Stang Racer
Ohio
Tom
2019 Mustang GT A10 301A
Question
This is a pic from inside the best I could get it to line up:shrug:
mustang_guy
United States
it has an engine!
Question
http://i.imgur.com/7119fRw.jpg[img][/quote]
Yours looks a bit more tweaked then others that have installed. Maybe try with the boot at the tb and try adjusting there then try the the stack to the tube boot again.
Stang Racer
Ohio
Tom
This may help on the air duct to bumper
Post #536 & #539:thumbsup:
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
Question
That's why you have a silicone coupler; it doesn't have to line up perfectly (and doesn't).
Evolvd
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Question
I had the same issue
Poppacapp
NC
2015 Mustang GT
**** My observations are in no way a slight or jab at Steeda. Their intake is a work of art, and in my opinion is the best looking option available for our cars. This is only MY observations, with MY car... you results may vary*****
So, I went back to the 1/8th mile track today with my stock intake in tow.
DA was 1600ft. 71 degrees
Steeda no-tune setup was already installed on the car, so I gave the car a good 40mins to cool down from the drive to the track. Ran the car. similar mph results as last week. 1.977 60ft, 8.36 ET @ 86.207mph. IAT in the 90s before staging
Swapped the intakes while letting the car cool down again. I did not choose to do a KAM reset/idle relearn because I felt putting the car in learning mode at the track might skew the results. If anything, a reset would have helped the stock intake even more. Reran the car, IAT similar in the 90s, although I had a little more idle time in the staging lanes on this run.
1.997 60ft, 8.418 ET @ 86.229mph.
Observations/Notes:
1) I removed air filters from both intakes during the runs to eliminate filter flow differences, and leave it to the intakes alone. I have made my stock intake runs with no filter in the past.
2) I gained zero power from the No-tune intake based on MPH today(which IMO is better than a dyno). 20rwhp would have shown if it were there.
3) The IAT seems to hover a little higher at the track in the staging lanes because the aluminum velocity stack holds more heat than the plastic OEM intake. I noticed this immediately after going to staging lanes with stock intake back on.
4) I feel like the Steeda intake would be pretty nice and beneficial with a tune to utilize it. In my opinion, Ford has their intake dialed in for the stock tune.
I would welcome some independent before/after dyno pulls with the No-Tune setup, although I don't see how much more accurate it can get doing back to back similar IAT runs at the same DA/day at the track.
As for now, I will leave the stock intake on the car, and retry the Steeda/OEM intake comparison with tunes for each at the track once I am ready to go with a tune.
My previous best ET/MPH with stock intake is 8.05 @ 89.6mph
Renner
Huntley, IL
2016 GT SOLD-2015 Ecoboost SOLD
Plastidipped mine black before install.
Steeda did a great job on this intake.
Khyber
Landon
2015 GT PP CO
looks good. i'm planning on doing my intake tube, coils, and engine cover CO(well vht or duplicolor chevy orange) at some point. I keep procrastinating
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
Observations/Notes:
Question for you! Since you are doing 1/8 mile drags, why did you choose a 3.15 gear ratio auto instead of a 3.55! I am assuming you are finishing on 3rd gear, but what rpm?
Steeda's test car was a 3.73 gear equipped gtpp, so my guess is that the auto's may not see the same results! The test also did a comparison with other intakes as well!
Honestly though, stock intake putting more mph in a 1/8 mile is interesting! You might be loosing some bottom end power and maybe the gearing won't allow you to use the top end! Have you tried 1/4 mile as well?
stoli
Fat Guy Racing
Lakeland, FL
'15 Black GT/PP
It's just the nature of open element filters. I had the same thing with the JLT. The Steeda seems to be a little better at idle and recovers quicker though.
As soon as my car is back on the road and I break in the new clutch, I'll be back at the track and I'll give all three a try with the Lund tunes; Stock, JLT, Steeda. If I can get my AirAid back in usable form, I'll test it as well.
I don't know if it's my best 1/8th, but as part of my best 1/4 it was 7.74 @ 88.0 w/JLT
At the end of the day, I'm not expecting much difference between them. I'm just pleased with what I feel is better low end smoothness than I had with the JLT.
Poppacapp
NC
2015 Mustang GT
I chose 3.15 gear because I have plans to go with a turbo setup, and 3.15 is the perfect gear for that route. As far as auto vs manual, power is power, and I didnt gain any. I have run at the 1/4 mile, and my best time is 12.46@ 109. That was the same run that I got my 8.05 1/8th mile run on. Also ran multiple 12.6s
