Sound tube delete question
georgev
Toronto
2016 Mustang GT Base Auto
I twisted the sound tube off, found it easier then pulling it off.
Bartly
Out West
I still want to know if it's any easier from under the car while on jack stands?
MedStang
Smoky Mtns
'16 Guard GT PP 401A
This was my post from a previous thread on the topic:
One of these worked perfect for me to plug the hole in the firewall:
http://www.ebay.com/itm/FORD-OEM-Spo...-/191570086736
And one of these to cap the whole in the stock air intake:
http://www.lowes.com/pd_37824-255-4440795N_
I have the PP with the braces. For the nut removal, I removed the sound tube from the air intake to swing it out of the way as much as possible. Then I used a 10mm ratcheting wrench and snaked my arm (tight fit!) from the front between the coil cover and the fender well to reach it. I didn't have to lay across the front like the other poster, but was able to do so from the side fender. Once the wrench was on, there was room behind the motor to swing the wrench to remove the nut. Once the sound tube is off, the firewall hole is easy to reach and plug.
^^Listen to this guy.
I did it without removing anything on my PP. It was a major PITA and took longer than it should have. It hurt like hell too with my big forearms.
scott_0
Oxford, Pennsylvania
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
If you lift the tubing out of the grommet from the brake reservoir you can get your hand in their easily to put in the firewall plug. I was trying to squeeze my hand in there and it wouldn't work. Lifted those tubes out and I can easily get my hand back there to make sure it was flush.
S550ilver
S550ilver
Bartlett, TN
Well got the tube out last night...no tools at all, and all I had to do was loosen the strut tower slightly. I used the twist method as suggested, and it popped right out. Didnt break any plastic tabs or anything...and it looks like the part around the 10mm bolt just kind of released itself from the tube when I twisted it...Now having said that, getting the plug in when I get my Blowfish kit in looks like thats going to be the hard part. I can move that brake line a little and hopefully fish my hand down without dropping the plug. Was very surprised how easy the tube came out...but I do applaud anyone who used wrenches/extensions/etc to loosen it...
StoplightWarrior
Bay Area, CA
2017 STi, 2016 Camaro SS, 2016 Infiniti QX50
I know it sucks, but just spend an hour in your garage and do it the right way.
I am a normal sized man and was able to squeeze my arm and hand down in there and eventually get everything off cleanly, in one piece, and capped.
GT Pony
Pacific NW
I used a 10mm flex head ratchet wrench to get the nut off. Took a while, but it wasn't too bad.
Before you try to install the plug, pop off the coil cover on the head. It will give you a little more room to get your arm down there to install the plug.
MSMStannyl
Baltimore, MD
2015 Mustang GT Premium - Triple Yellow
Someone else asked this earlier but I didn't see a clear answer and am curious myself. I've heard of lots of people removing the sound tube but what is the benefit of doing this? Just wondering. Is it just to get rid of excess induction noises? I guess at least with our GT's, it's actual engine sound and not a soundtrack coming through the speakers...
T-S550-X
DFW, Texas, USA, Planet Earth, Milkyway Galaxy
Naji
DIB 2015 Mustang GT PP
The only real noticeable difference is the unsightly clutter that goes away with the sound tube. I personally did not notice any sound volume difference. I prefer the cleaner look of the delete.
natepcbfl
New Hope, AL
Nathan
2015 Mustang Premium GTpp 50th AP ---- 1989 Mustang GT 25th Anniversary
I keep seeing different firewall plugs to use 1" - 1&1/2". Can anybody say what size hole is actually in the firewall?
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Yeah, I did it as part of an install of an air intake elbow (that removed the air tube connection), mostly wanted all that cleaned up (it's amazing, the amount of shit that comes out with the sound tube).
However, I did actually notice some weird harmonic sound disappeared, that was introduced when I had my stock intake (and tube), and added my Mach Thunder exhaust.
I used this one:
https://www.amazon.com/gp/product/B000C5E4O6/
Gee
RI
