honeybadger
Just don't care
Recommend adding valve spring failure
HB take a look at the poll. I think you and one more are the only two I know off with valve train failures.Recommend adding valve spring failure![]()
HB is one of the few who knows they had a valve train failure, but if a bigger broken spring chunk had gone into the pump, he'd have reported "yet another OPG failure". My suspicion is that a lot of the OPG failures actually started with something else failing.HB take a look at the poll. I think you and one more are the only two I know off with valve train failures.
I am not aware of (if) any failure blamed solely on the OPG. The other guy I know had a valve keeper fail and his OPG took some damage.HB is one of the few who knows they had a valve train failure, but if a bigger broken spring chunk had gone into the pump, he'd have reported "yet another OPG failure". My suspicion is that a lot of the OPG failures actually started with something else failing.
So, with all due respect: this thread has had 93,000 views, 1,500 replies but only 8 people who actually voted and reported issues. If this is indicative of a huge problem, im not seeing it.I am not aware of (if) any failure blamed solely on the OPG. The other guy I know had a valve keeper fail and his OPG took some damage.
This thread just got modified the last day to a new title to better reflect reality plus a poll added so give it some time to populate. Perhaps the mods could sticky this so it stays on top?So, with all due respect: this thread has had 93,000 views, 1,500 replies but only 8 people who actually voted and reported issues. If this is indicative of a huge problem, im not seeing it.
Thanks Rick!This thread just got modified the last day to a new title to better reflect reality plus a poll added so give it some time to populate. Perhaps the mods could sticky this so it stays on top?
Edit. Nevermind you did.2017 GT350R #HR875 replaced engine due to oil consumption at 17k miles
Already did. Good heads upAt the very top of this thread there is a poll. please mark for engine replacement reason.
Thanks
H
And engine builders ;-)I would also be interested to see if there is a correlation between manufacture month and year..
From the information in this thread, over 1500 posts, engine builders and year build has absolutely no relevance to why an engine was replaced. I recommend you read through and come to that conclusion yourself. The OP's intention was to be informative. Most engines in this forum and other forums to include FB seem to be due to oil consumption. To me that speaks volumes.And engine builders ;-)
