Recommended Fuel System for E85 S/C??
beefcake
Bethel
2018 Ford Mustang
fore is as good as it gets,
they make the highest quality stuff on the market, and they stand behind everything 100%
we are their largest dealer and can steer you the right direction for what your looking for
your tuner will def be fine with their stuff
513-478-1965
Doctor Fishtail
Doctor Fishtail
Mexico
Mustang GT
513-478-1965
Will check with Ken via email. Sounds like a go. Thanks.
beefcake
Bethel
2018 Ford Mustang
Jay-rod427
Kansas
2016 GT C/S
E85 for FI without a fuel system is asking for serious trouble. Fuel isnt something you play around with.
Keep in mind he states only wants 700 rwhp ( how long that goal lasts, and is accurate is a different story). That is nearly doable on the stock pump without BAP on 93. E85 needs more fuel sure, but not a ridiculous overbuilt system designed for 1,000 hp.
My tuner told me the same thing.
Have not tried yet. Still running Stage 1 Roush injectors and 90mm pulley. Raw fuel smell sucks. This is one reason want to go back to Korn. Figured I would go smaller pulley with BAP but does not look like a good idea.
Plenty of guys running BAP with zero issues.
You can hit your goal for a few hundred bucks, or you can spend a couple thousand you don't need to.
beefcake
Bethel
2018 Ford Mustang
system isn't a couple thousand, and again,
35k car, 6-10k in mods, but cheap out on fuel.... makes no sense
just because people are doing it, doesn't make it the right thing to do.
how many people doing it are actually logging fuel pressure. fuel pressure takes a nasty drop on e85, with decreased fuel pressure, your one negative power spike away from pumps not keeping up
the larger injectors help maintain a/f with the lower pressure, but it's band aiding the system.
by all means, if you don't want to spend the money don't, but we won't tune for it.
Jay-rod427
Kansas
2016 GT C/S
$1,261 for the base bare bones lvl 1 fore system not even including the electronics, and $960.00 for ID 1,000's he's been recommended so yes a couple grand...
beefcake
Bethel
2018 Ford Mustang
injectors is not a fuel system, injectors you will need whether you do a fuel system or not.
Jay-rod427
Kansas
2016 GT C/S
What are they the part of the charging system?:doh: Couldn't help not being an ass LOL.
daltron
Rowing All Day
Jonathan
2016 GT PP
Your advice to run E85 without a fuel system with FI is going to destroy someone's motor.
Farrdaddy
Ohio
2015 CO/PP
Will he tune with the 72s in the whipple kit if I buy the rest of the fore fuel setup?
beefcake
Bethel
2018 Ford Mustang
yes
but, you will be limited on power, they typically run out of steam about 6500 rpms
Farrdaddy
Ohio
2015 CO/PP
yes
It pulls thru 7200 now with whipple tune. Am i missing something about how it would do on e85. Thanks for your help
daltron
Rowing All Day
Jonathan
2016 GT PP
E85 requires a lot more fuel volume, so depending on your goals I'd get at least ID 1000's or ID 1300's.
