Rear end upgrade options
Prodigal
OKC
2021 Mach 1
that is PB, on the car
Been to Bithlo many times back in the early 90’s when it was way out in the sticks. My 87 IROC vs my brothers 88 notch back. Learned then that tge Mustang was the better way to go!
NGOT8R
Adrian
2019 Bullitt
Turns out the issue wasn’t an halfshaft like I thought it was. This time was my rear end one planetary gear decided it had enough. I’m glad it was the diff and not the axles
What are you going to put back in there (a spool or something better than the factory setup)?
Coyote Chase
Don
2010/2018 Mustang
Bithlo Florida? As in Orlando Speed World!?
NMRA's Spring Shootout 2023 is scheduled at that track March 2-5!
15Oxford5oh
Orlando, FL
Brian
2015 Mustang 5.0.
I was looking at entering my car in the true street stick shift class if I can get a fuel system before then. Anyone else in here going?
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
What did you end up doing ?
Oakley
Lee
2022 Mustang
this may seem off the wall but have you considered a CF driveshaft? it might help dissipate some of the initial shock of the launch. MT82's come with steel pumpkins for a reason
TOROz06
TOROz06
Orlando fl
17 mustang gt
Couldn’t find a better solution with out spending a ton of money, I bought a used stock rear end, last time out 4th gear finally gave out, so is time to make a decision. Stay with the mt82 and rebuild it stronger but keep all the drivetrain issues or replace it with a turbo 400 and call it. The th400 should help with all the drive trail issues.
TOROz06
TOROz06
Orlando fl
17 mustang gt
My driveshaft is carbon fiber already. Also I believe that my suspension was set too tight making the car wheel hoop causing all the damage. We dialed back and reduced the launch rpm’s and the car left the line but sadly my factory mt82 had enough, can’t really complain about it she hold for a long time.
Oakley
Lee
2022 Mustang
eep, well more than double factory power is kind of asking a lot :D
NGOT8R
Adrian
2019 Bullitt
Have you pulled and opened up your tranny to inspect it yet? Just curious as to what type of damage you may have found? If you decide to rebuild it, please document it for us and let us know what lived, died, or was seriously damaged inside. good luck on whatever you decide to do?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Instant application of power via the clutch is your issue. Do you know how a slipper clutch works? Softening the hit is you're solution. The Clutch Tamer makes a hydraulic version you can look into.
