Rear axle thrust washers
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
specifically : FR3Z-7G273-A
Can't seem to find them @ rockauto.
Perhaps I'm not searching correctly ?
If somebody would have a link to it @ rockauto that'll be awesome. Thanks !
MyStang
Michigan
2015 GT
Dealer item, that's the only place I could get them price wasn't to bad.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
SBR70.3
Edmond, OK
2021 Mach 1, 2016 Mustang GT Premium, 2023 Explorer ST, 2019 GTI (DD)
Ya, I had to go to the dealer and explain the part as if I was talking to a 6 year old. The install was easier than talking to that guy. While you are in there, might be a good time to upgrade the hub assembly to the FP version, assuming you haven't done that yet.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
gotta hub with lifetime warranty through work and ordered the washer through a local dealer.
17MagMetal
San Francisco
Michael
17 Mustang GT, 07 Ford Taurus SE, 95 F250 Xlt
I went through the dealer.
such a PITA cause you gotta rip the knuckle off to get to it lolol. Good chance to do the toe link bearing.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Takes me about 45 mins a side to take out the axle shafts.
17MagMetal
San Francisco
Michael
Do keep an eye out for the washer you receive.
The originals were paper thin which caused a click upon direction change for some (me), the revised ones were probably two mm thick.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
So what exactly do they do ?
Roadsign
2016 Mustang GT PP
Preload on the bearing and/or stops the clicking some experience. There seems to be some conflicting info. Some found they were never installed from the factory and don't have an issue.
I've always used them and never had the clicking so who knows.
Also, maybe there's a difference between years but on a 2016 the knuckle and axle don't have to come out to replace the bearing, just get the brakes out of the way.
17MagMetal
San Francisco
Michael
From my understanding they just put preload on the axle. They take up the slack between the knuckle and the face of the CV.
Not an engineer though, I’m sure someone here can confirm that.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Me either.. if all it does is take up slack, can't it be replaced with a flat washer ?
17MagMetal
San Francisco
Michael
You might be onto something, but I think the nibs on it act as the “spring” to keep tension where the axle/knuckle meet.
It must be needed to allow a few mms of side to side movement with the driving of the vehicle. No clue what that does for driving characteristics/handling.
