Quick Jack 5000 at Costco
MA
DC
2017 GT-350, 2008 WRX Sti, 2017 VW GTI
Thanks for the guidance, I ended up getting the Steeda rails.
imbadatthis
GT350
If you live in DFW, the Costco in Duncanville has them in stock for $999. You won’t have to worry about the biggest complaint in reviews, which seams to be damage during shipment.
Just picked mine up from Frisco. They had a dozen or so.
mrbillwot
Greater Boston Area
Bill
'19 Kona Blue w/blk roof & blk stripes GT350, 89 LX5.0 Sedan (Mustangs Past: 69's Coupe, Mach 1, & GT)
Why small in front?
I use large front and back. The BMR jacking rails end up 18.875 (7/8) off the floor. It's a tight squeeze to get the large blocks in after its under the rails but since the blocks set down inside the quick jack, its easy to put the front large ones in before positioning them under the rails.
Which BMR rails did you go for? The longer or shorter low profle ones? Are they visible from the side (would red show on a dark GT350)?
nordique14
PNW
sold my 2018 GT350 :(
I bought the low profile. If you want them to blend in, get the black hammertone. On my magnetic car you do not notice them. They hang a mm or two below the pinch welds. Probably plenty of pics or YouTube videos with them installed.
HoosierDaddy
Randy
Another.. I don't set any reason to add the weight of rails
Pros and cons for both. One of those is being able to lift one side of the car with a single floor jack placement and operation. Very handy at the track when your pit crew is on strike.
HoosierDaddy
Randy
Low profile. All my BMR stuff is red but I can't see the rails from any distance unless my eyes are lower than the side splitter (don't know proper term) In fact, they tuck up so high when I lift the car on the QuickJack those side pieces touch the QuickJack.
mrbillwot
Greater Boston Area
Bill
Sounds good - thanks for the input guys!
firestarter2
firestarter2
NYC
RR G350 Track
You can lift the GT350 by jacking any point on the side of the car. So you do not need rails for that.
DroptopGT
Seattle
Colin
2016 vert GT
Has anyone tried on a lowered car? Read they need 3” of clearance. I have eibach sportlines with 295/30/20 squared on my car.
1 old racer
Fontana CA
Will
The quick Jack's will lower to about 3.25 inches. And my lowered PP1 is 3.75 at the lowest point with Steeda jacking rails being the low point. I store the quick jack under the car in the center of the car. I am actually going to build a drive on ramp using 2x8's and just remove the center section and slide the quick jack into position. I will post when I do this.
Rubyred17
Kentucky
2017 GT350
Hello
My local store just received several of these and I am very tempted to buy it. However, can someone tell me if puck or pads are required and if so, what is the best ones to use. Pictures would be very appreciated
Also, in the winter can the car remain elevated to keep the tires off the ground?
Thank you
armsdealer
Baton Rouge, LA
2019 Kona Blue Mustang GT Premium PP2
Hello
Thank you
It comes with a set of short and tall rubber blocks. You will need something to protect your pinch welds, or just get some rails. The pinch weld blocks quick jack sells do not fit our cars without modification. The puck style pinch weld blocks suck and will more than likely split in half.
The longest I kept a car up was over a weekend, it was a BMW getting a complete suspension/control arms/bushing/guibo overhall. I am not sure I would plan on keeping a car on it all winter.
1 old racer
Fontana CA
Will
Thank you
That is something I would ask the mfg. just to be sure. However when you use the quick jack properly you will jack it above the first stopping point and then you lower it to lock the safety stops into place. It takes the load off the piston and seals. So with that it should be ok.
DroptopGT
Seattle
Colin
2016 vert GT
I just read on their site it that basically the said it was ok. Check out the frequently asked questions. As for using the pinch welds I read in another thread someone recommended zL1 add on to access the pinch welds
