Q&A with Dave Pericak
PremiumT
Guest
So we know the 4 cyl will be lighter and more balanced. Question is how much so? Are we talking 100+ pounds and near 50/50?
Whiskey11
Kill ALL the Cones!
US of A
2016 Ruby Red Base GT/PP
Assuming the 15" brakes are legal in the class you want the Mustang to compete in, which setup would you choose?
For autocross only? I'd chose the floating calipers and 13.2" rotors (or whatever they are) for the 2.3L. Less overall weight and I don't need the 15" brakes because autocross is not hard on brakes. This provides me with the option of "upgrading" to one of Wilwood's lightweight brake setups with the smaller diameter rotors. The class I'm in stipulates that brake rotor diameter does not decrease for your optioned car so this would allow me to use their 13.5" setup (it's a drag racing setup IIRC) and keep weight down.
What will I actually be getting if Ford hits my weight goal? The 14" brakes are more than capable on a 3700lb (with driver) Mustang GT with some attention paid to cooling on a road course. That is all I'll need since I will want to take the car on a roadcourse eventually. I have the floating calipers on my GT and they work fine for autocross but they are NOT up to snuff for roadcourse duty. I just don't like the idea of the base 2.3L either if there are going to be differences in the drivetrain.
My gripe with the 6 piston, 15" rotors has more to do with wheel selection and then the drastic reduction in tire selection than it does actual performance. If more 18" wheels fit the 15" rotors (the Ford Racing BBS wheels on the FR500/Boss302R clear them in 18" and are the only confirmed 18" that does) I might have changed my mind but since barely any do the 14" is my choice. 19" tires are expensive, the wheels are still heavy and even if they weigh the same the rotational inertia is more because the weight is another half inch further from the hub. Stopping distance wise there is no difference between the 14" setup and the 15" setup. Will it feel like there is? Yes, but there wont be a measurable distance so long as they are on the same tires and weigh the same with the same weight distribution. The tires have been a limiting factor in stopping distance tests on the Mustang since well before 2005. What it will do is take the repeated abuse of road coursing longer. In autocross we don't get brakes hot enough to justify massive brakes with cooling ducts unless the car is dual purpose. We use the brakes a lot but they never get that hot since the speeds are significantly lower.
We already know that the 2.0L Ecoboost is around 478lbs (per:http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=22999), the 5.0L is 544lbs (per:http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=13113) and those are dry weights, no oil. Somewhere between 75-100 less in just the engine. My 2009 sits at 52.6/47.4 weight distribution and 100lbs off the nose would throw it at 49.9/50.1.
Husker
Just The Basic Facts
Lincoln
Harley
F-150
((( OT WARNING )))
I see you are from the land of the Corn, will you be entered/driving at the Airbase in Lincoln this May & Or September-August?
SCCA
Grimace427
NoVA
2011 Mustang 5.0
Well it looks like they have their bases covered, 13.2" brakes for the auto-x crowd fitting into their chosen class, 14" for higher classes, HPDE enthusiasts and club racers fitting their class, and 15" brakes for peak performance wherever it can be used.
Back when we were comparing the 5.0 Mustang to the E9x M3 the engine weights were compared and I thought the Coyote weighed in at 435lbs dry compared to the 445lbs of the S65 4.0 V8 BMW engine. I think the weight you quoted includes the pallet and whatever other materials used for shipping.
Whiskey11
Kill ALL the Cones!
US of A
((( OT WARNING )))
SCCA
May, probably not, September, I'm going to try my damndest. I'm going to try and be there for the regular events too. If you are in the Omaha/Lincoln area, www.nrscca.com is our local region.
PremiumT
Guest
That's some serious balance right there. I guess we won't know for sure until they tell us as it has to factor in the IRS and the changes made to proportions. I think a few they mentioned was the A pillar being shifted forward if I'm not mistaken. either way the lower CoG and wider track should help with weight transfer. It makes the I4 a very very attractive option for those that are not all about pure hp and can live without the V8 note.
PremiumT
Guest
I was under the impression that the regular base GT would beat the Boss 302 around a track. Does this mean that only the PP equipped GT can?
My guess is base GT will have the same performance as the B302 and the PP would handily beat it. He did say "for sure" outperform. Exciting times, I can't wait to see it get tested. :hail:
tdmp
2015 Ford Mustang top speed revealed
Per the article:
In an interview with Autoevolution Mustang Chief Engineer Dave Pericakhttp://video.foxnews.com/v/28974899...tang/?playlist_id=2366201037001#sp=show-clips revealed that coupes with the carry-over entry-level 305 hp V6 will have their electronic limiters increased from today’s 113 mph to 121 hp, while 5.0-liter V8 models get a boost from 149 mph to 155 mph.
As for the 300-ish hp 2.3-liter turbocharged four-cylinder that will fall between the two naturally-aspirated engines in the lineup, it will come with standard a 121 mph limiter, but cars equipped with the optional high performance Track Pack will be able to hit 145 mph, which a Ford spokesperson tells FoxNews.com is also an electronically restricted speed.
Rickycardo
Bolingbrook, Illinois
2015 GT auto
Any car with an electronically restricted speed can be electronically unrestricted.
Rickycardo
2015 GT auto
Q: Any plans for a Boss 302 replacement?
A: We've been in (Mustang) business for 50 years and if you look at what we've done, the Mustang has always had specialty cars and performance vehicles. You can expect that we're going to stay on the same path. Today, we're here talking about the new Mustang, so we're not talking about any plans for future cars at the moment, but it would be wrong for me to say that we're not going to do that. It's been in our blood, it's been in our history, so stay tuned.
Great! I can see a 2015 convertible GT California Special with lots of carbon fiber trim!
Whiskey11
Kill ALL the Cones!
US of A
I don't recommend doing that with the V6 Mustang if they chose a driveshaft that comes apart a few MPH after the electronic limiter! :thumbsup:
Well, I wouldn't recommend that for ANY car, but best to make someone else do it first! :)
thePill
Camaro5's Most Wanted
Pittsburgh
S550
Sir, the exact weight of the Coyote 5.0, ready to run is 429lbs.
Whiskey11
Kill ALL the Cones!
US of A
Ok, my point still stands as the important part was the delta between weights. :thumbsup: I have yet to hear what the Ecoboost 2.0L weighs with turbo plumbing and all that... hell I can't even find what just the block weighs so that packaged weight is as close as we get.
Still if the GT is going to remain the same weight, that puts the Ecoboost somewhere in the upper 3400's to low 3500's for weight... Kinda a pig for a Turbo 4. Come on Ford, bring on 3300lbs or less! :)
Free Agent
2015 GT Premium
Illinois
2015 Mustang GT Prem.
With all the secrecy on weight, I just have this sneaking suspicion that we are going to see a slight gain on all models. Ford went out of their way on the F150 to tell us about the 700 pound weight loss. Still nothing for the Mustang. It won't spoil it for me if it picks up a minimal amount say less than 100 pounds. But it will be a BIG disappointment with all the hype about weight loss leading up to it.
One worry that I do have is that they might be pouring over parts from suppliers and having them reduce mass by making the parts thinner, having more open spaces and the like to save every gram/ounce they can. This could lead to poor build quality. I'm sure its a fine line between quality and reducing mass. I think I'd rather have a slightly heavier vehicle with better quality materials than a lighter one with cheaper materials or quality.
Here's to hoping it still drops a little for each model though. I will reserve judgement.
