Beerdy
Mine doesn't. It goes to zero and stays.Yes...it will show positive numbers on the digital display.
Looks bad ass! What hood is that?Forgot to include pic of car with hood closed
Quality is top notch, fitment is good but took a while (but this normal for most hoods I believe).How is the fitment & quality? Is it lighter than the OEM?
Thanks man!!! I appreciate everything you have done.hey buddy. as i mentioned i'll get the surging sorted out. some do it some don't. it seems to be more prevalent with the HO kits. also the car was only "tuned" up to 6k ish. and you are on your second revision. NOW you can go up to 7200 or so (that's at least another 50 wheel hp) send me a log of a 2k to 7k ish 3rd gear pull and i can lean on it a bit harder
and get with prochrager for the inlet.
then lets get this thing on a dyno and check the numbers
How much boost are you running?Keep in mine you have one of the first kits sent out by Procharger ..I know the guy you got the kit from ... You have a 4 inch pulley ... Later kits like my HO kit came with a stock 3.70 pulley .. So you will be down on power with a 4.0 pulley ...With a 3.70 pulley power will come on faster ..The surge problem can be tuned out .. I have dropped down to a 3.50 pulley on mine and added ID1000 injectors and a BAP .. I had Sai Li retune it ... 604 HP/561 TQ and that is with a auto trans that makes less HP on the dyno than a M6 would ..If it were me I would call Sai and have him put it on the dyno and tune it .. My car makes so much TQ down low I can't hook the car in the first 3 gears ..Even with Drag radials at the track I have problems hooking the car in first gear and shifting into second sometimes ends up sideways ..
I was at 8 to 8 1/2 with the 3.70 pulley ...With the 3.50 I have no clue because the factory boost gauge took a crap ... It only goes to 3 PSI now .. I'm going to install a aftermarket gauge soon .. My guess it's 10 to 11 psi right now ..How much boost are you running?
What rpm with the auto?I was at 8 to 8 1/2 with the 3.70 pulley ...With the 3.50 I have no clue because the factory boost gauge took a crap ... It only goes to 3 PSI now .. I'm going to install a aftermarket gauge soon .. My guess it's 10 to 11 psi right now ..
7k shifts , I wanted it higher but the engine flat lines at 7k .. The power doesn't drop off at 7k but just stays at the same HP till 7500 ... Tuner said I was running out of fuel after 7k ..What rpm with the auto?
Thank you for that information. I believe Jason is giving me the 3.70 pulley next week so I may go ahead and throw that one on there.Keep in mind you have one of the first kits sent out by Procharger ..I know the guy you got the kit from ... You have a 4 inch pulley ... Later kits like my HO kit came with a stock 3.70 pulley .. So you will be down on power with a 4.0 pulley ...With a 3.70 pulley power will come on faster ..The surge problem can be tuned out .. I have dropped down to a 3.50 pulley on mine and added ID1000 injectors and a BAP .. I had Sai Li retune it ... 604 HP/561 TQ and that is with a auto trans that makes less HP on the dyno than a M6 would ..If it were me I would call Sai and have him put it on the dyno and tune it .. My car makes so much TQ down low I can't hook the car in the first 3 gears ..Even with Drag radials at the track I have problems hooking the car in first gear and shifting into second sometimes ends up sideways ..
let me know if you go that route. one i have to tune it, two i can hook you up on a deal with the ids:cheers:Thank you for that information. I believe Jason is giving me the 3.70 pulley next week so I may go ahead and throw that one on there.
Also he is giving me the Boost Pump, so I may order the ID1000's and install both of these also.
With the 3.7" i was at 8.9psi at 7250. I am running the 3.6" now and am at 9.7psi. Also long tubes and stage 2 IC.Thank you for that information. I believe Jason is giving me the 3.70 pulley next week so I may go ahead and throw that one on there.
