Opg install, Whats all required?
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
Now that I removed the balancer I noticed the front main seal is a little torn but isn't leaking. I figure I might as well replace it while I have it apart. Does anyone know the procedure for installing a new one? Do you install the new one with a thin layer of rtv on the outside?
i believe you only need to put silicone at the locations you where you are required to clean off the old. you do not have to bead all the way around the seal, just bead the couple spots when you close it up as per the service manual. :cheers:
TheHydro
Las Vegas
2015 GT Performance Pack
The seal I'm referring to is the round one on the front timing cover that the crank goes through.
GT_Tommy
San Luis Obispo, CA
Tom
TVS Supercharged Premium PP
The FSM links provided earlier in this thread don't show the crankshaft seal install. According to the timing cover guide this is the section you would want:
Refer to: Crankshaft Front Seal (303-01C Engine -5.0L 32V Ti-VCT/5.0L Ti-VCT V8 (308kW/418PS), Removal and Installation).
Let me know if you're having trouble finding that seal. I ended up ordering one but didn't use it because mine was perfect. Part number: FRONT CRANKSHAFT SEAL XW4Z-6700-B
TheHydro
Las Vegas
Thanks for the help. I just ordered the seal so hopefully I'll have it this week. Does anyone have a printable version of this install guide?
B Gordon
Tulsa, OK
Bruce
Yellow 2015 GT
Since I am not much of a wrench, can any of you helpful folks point me towards a reputable (and experienced) installer who can replace my OPG with a more durable replacement.
I live in Tulsa, OK but wouldn't have a problem driving to Dallas to get it installed by a shop with experience and a proven record.
My only other option would be to have it done at a local Ford dealership, which can be a bit hit & miss from what I understand.
dsp4848
Hutto, Texas
David
2015 GT PP Magnetic
Sent you a PM. Sorry, haven't been online in a few days before today.
Not sure about Tulsa, but I would bet that you can find someone in Dallas that is reputable and will do it for a fair price. There's a decent number of DFW guys on the forums that can probably chime in. I personally wouldn't mess with a dealership, but that's me.
Does anyone know if the 2018 will be built with revised OPG, crank sprocket, primary tensioners or TG?
It would be a nice revision, right?
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Great question for sure. I know the added horse power attained from a higher compression ration and higher rpm resulted in Ford adding better and revised crank and rod bearings. I would think OPG nad crank gear would be in order.
Brn N Rubr
Burleon, TX
2015 CO GT PP
So, has anyone replaced the oil pump bolts due to being TTY? Or just retorque utilizing the original bolts and factory torque specs?
Brn N Rubr
Burleon, TX
2015 CO GT PP
The four bolts that hold the pump itself to the block.
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
I personally reused mine and I would say that's what the majority has done. I'm m going to look at the manual now. Don't remember those being torque to yield.
db252
Equinsu Ocha
Bay Area, CA
Yeah, those don't need to be replaced. They are just torqued in stages. Not tty.
Brn N Rubr
Burleon, TX
2015 CO GT PP
Gotcha. I just saw the "turn xx*" and just assumed. Just making sure all my ducks are in a row for next weekends install. Thanks for the quick reply!
db252
Equinsu Ocha
Bay Area, CA
No problem. You'll hardly think it's tight enough when using that low of inch pounds but its all you need. Good luck and take your time.
