Oil and filter change
Kenbike
Ohio
2015 CO Mustang GT convertible loaded
My new Quickjack 7000 showed up and lifted the car, these are going to be great for oil changes, tires and detailing.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
'16 CT6, '18 SD, '20 GT 500
Have the same one, Ken, and other than the time it takes to setup, it's a very handy device. MOF, the car just told me it was time for some fresh erl yesterday. (Pretty sure I forgot to reset the monitor last time but she's due by my meter so I'll get tuit Real Soon Now. :-)
Applied Carbon
SE PA
Fred
2022 GT
Just a warning to any driveway warriors doing their first 5.0 oil change, that oil comes out FAST. My catch can is the type where it drain down from the top and the Mustangs mighty stream overwhelmed the little hole and made a MESS on my ep henry driveway.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
It sure does, Fred. I got lucky having a big one for the F250 the first time I did the Predator motor. When you have nearly double the volume of oil subject to good old gravity, the pressure is also a lot higher.
Sorry about the driveway, I hate getting it on the porous concrete as it takes a whole lot more effort to get out the stain. Good luck.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
I highly recommend a Fumoto valve, makes oil changes so easy!
Melmark93
Iowa City
Mel
2020 GT500 Kona/White stripes, 93 MarkVIII Vortech, 94 Mark VIII, 13 MKS Ecoboost
Ditto what Evolvd said!
Applied Carbon
SE PA
Fred
2022 GT
Had one on my WRX and never liked how it hung off the oil pan. Ended up going back to the factory plug style. Gonna get one of the UPR metal drain plugs with the magnet next oil change.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
The one I have doesn’t hang low and the outlet sits just a bit higher than the belly pan. But, it’s also for a Shelby so I can’t speak for other models.
kilobravo
Corpus Christi, TX
kilobravo.com
KB
Thanks, B, forgot to mention that small but important factoid. It also prevents oil from the belly pan.
Fumoto should consider this idea. I always liked having a "Chip light" in some of the aircraft I've flown. Not really an issue with turbojets but it is for turboprops and piston engines.
Rapid Red
Woodstock GA
Greg
I third that emotion, make it much easier with a smaller orifice that doesn't explode with a 3/4" stream and no trying to find the oil pan plug. :-)
This will control the oil flood, never spill a drop again
Quick Jack friendly
Nawsad123
Everett
Bonez
2017 Mustang GT
My 17 GT sits for almost 5 months a year. Get an oil change every season ~1k miles. Pump the tires up, n change out oil when your ready to take her out. With the frequency of oil changes I do, im not worried about sludge/ contaminents letting the car sit. Put it on a tender and let her rest
Melmark93
Iowa City
Mel
Fumoto is above the belly pan. Blue clip is the safety lock. Just attach a hose, put it in your drain pan, remove the blue clip, lift the lever up out of it's locked position and rotate to open. It is as mess free as you can get. I have a black vinyl cap on the hose barb to keep everything squeaky clean.
TeamGomez
San Diego
www.centripetalsolutions.com
'18 350, 996 GT-3, E46 M3, SQ5, Tundra
We discovered magnesium oil pumps in 993 3.6 l engines were getting hammered by sulfuric acid...did some homework and discovered that the sulfur dioxide released by gasoline combustion slowly forms sulfur trioxide, which reacts with water to form sulfuric acid. I would always ensure to drive to op temp b/f parking and if that cannot be done, I wouldn't let a car sit with contaminated oil over the winter. YMMV.
